Time/date are wrong this all happened after battery fell out of phone..,
SOURCE: motorola v170 tracfone
press the center button. Then press the down arrow. when you get to 'recent calls' then press 'select.' You will have three choices, select received or sent or missed. When the call comes up, then press the center button again and you should have a choice of deleting that call. Press yes, the white dot on the right.
SOURCE: MOBILE PHONE -24 HOUR TIME
Goto settings or tools their you see "Date and Time setting"! Their you can change your time as like your wish!
SOURCE: Unable to change the time.
MY W175 Automatically changed to dst. Had to turn it off and I dont remember if had to take the battery out or not, but when it finally picked up service the time was daylight savings time.
SOURCE: With my Motorola l6 i phone i can't open initial
hi,
i would try to help you out in this regard, but before this let me know whether you have set any password to other options in the settings like.. personalize, or ring style or connection or call divert.
if you have the password to any of these, first try to remove the passwords to those options and restart your mobile, this should be fixed, you may ask that what is the relation b/w this option and other options, this could be because of some bugs in software building..
if the issue persists, write back on this with the exact error message you see.. or any thing that happens when you try to open it...
Narendra Tirunahari
