Question about Garden
Mitsubishi tu26 fuel cap needed - Garden
2 Suggested Answers
  • 42218 Answers
SOURCE: How do I start my TU26 Mitsubishi
switch it on, pull the choke ,press the primer bulb until it is full with not bubbles , hold the throttle full open, pull the cord several times
if it fires open the choke, press the primer once , hold the throttle wide open and it should go after 1-2 more pulls
hold the throttle open for several seconds after it starts
if you do not get a fire , remove and clean the plug
Posted on Aug 31, 2017
Need to tighten fuel pump cap on 2008 Mitsubishi Eclipse. Diagram of fuel pump? Where is it?
The fuel pump is located in the pump assembly module inside the fuel tank. There are plenty of photos of the pump and the entire assemby on line(such as parts stores) if you care to look them up.
The pump assembly module is accessed from the top of the fuel tank. In earlier models of your car you could access this by removing a plate on the rear floor of the car above the tank.. I am not sure if you can on your later model as in many vehicles you need to remove the fuel tank from the car to access the fuel pump assembly.
I am not sure what the person who referred you to a "fuel pump cap" really means. Perhaps you could get that person to explain what he meant. Possibly he actually meant the fuel cap on the fuel filler tube.
Apr 10, 2016 | 2008 Mitsubishi Eclipse SE
Problem with steady check engine light
2001 Mitsubishi Eclipse - CarCareKiosk
www.carcarekiosk.com/.../2001_Mitsubishi_Eclipse_GT.../check_engine...
... steps to diagnose and clear a check engine light on a 2001 Mitsubishi Eclipse GT... Steady Check Engine Light: If your check engine light is on every time you ...
Sep 25, 2015 | 2001 Mitsubishi Eclipse GT
What does the code p0442 mean on a mitsubishi montero sport 2000?
Trouble Code: P0442
Most likely the gas cap.Hope this helps. Randy
EVAP Control System Small Leak Detected
Possible Causes:
Canister Purge valve is damaged, leaking or it has failed Charcoal canister is loaded with fuel or moisture Fuel filler cap loose, cross-threaded, incorrect part or damaged Fuel tank is cracked (leaking), or a leak exists in the 'O' ring Fuel tank pressure sensor is damaged or has failed Fuel vapor line(s), fuel pipes or hoses damaged or leaking PCM has failed
May 09, 2012 | 2000 Mitsubishi Montero Sport
I have a 2003 mitsubishi lancer I'm getting the
Inspect for crack on the air intake tube between the Mass Air flow (MAF) to the intake manifold on the motor.
A loose clamp or crack on the air passage way will cause this problem.
P0442 code takes 2-5 drive cycle to reset by itself.
Do some mix city / highway driving.
If there is no EVAP leak then it should be clear within 50 miles.
Aug 11, 2011 | 2003 Mitsubishi Lancer
Mitsubishi 98 faulty fuel cap, leaking vent or purge solenoid, evap hose faulty, leak on fuel tank, PO455
Mitsubishi 2006 faulty fuel cap, leaking vent or purge solenoid, EVAP hose faulty or leak on fuel tank.... replace the fuel cap and a week later the light was back on...the code is P0442..what to do next
Aug 01, 2010 | 1998 Mitsubishi Eclipse
Need to find the fuel filter on a 2000 mitsubishi galant
The fuel filter is located in the gas tank. You have to take pump out of the tank to change out the fuel filter .
If you're going to replace a fuel filter make sure you have the right tools to do the job (Don't use a screwdriver to pop a pressure clip connection) And pop the gas cap before you pull the filter... It's better to get a drizzle of gas than to get a pressurized shower.
May 02, 2010 | 2000 Mitsubishi Galant
95 mitsubishi mirage has fire wont start
check for fuel pressure should be around 45 to 55 psi there should be a valve on the fuel rail with a black plastic cap kinda looks like a bike tire valve u will need a fuel pressure gauge .
Jan 08, 2010 | 1995 Mitsubishi Mirage
The check engine light comes on my 2004 galant es and the codes states that there may be a leak in the fuel line or tank evaporation system. What to do?
Have you checked your fuel cap? A loose or leaking fuel cap will trigger an EVAP code. I would start with a new fuel cap, and have your local autozone, or checker, or automotive store clear the check engine light after you replace the fuel cap. Hope this helps
Jul 18, 2009 | 2004 Mitsubishi Galant
What would cause the fuel trim check engine code?
It sounds like it is telling you that the Fuel Cap needs to be Replaced. if the Seal on the Cap is Bad, It will **** air into the Fuel tank.
Jan 23, 2009 | 1997 Mitsubishi Mirage
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
