Question about Andis Health & Beauty
Andis power groomer is shaving unevevly
The shaver shaves really unevenly and pulls
SOURCE: Carrera Shaver NC accu
Contact the Carrerra Customer Service Hotline at: 1-888-476-1785
Posted on Mar 08, 2008
Blondie Girl
  • 25 Answers
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
brector3
  • 1602 Answers
SOURCE: My F-5790 doesn't shave any longer. The shaving
If the shaver heads pops up, this is because you have not cleaned it properly. This is common on this model type. You will need to thoroughly clean the top of the shaver body. Remove the cutters so that you can access it properly. You may need to use a toothpick or similar object to loosen and remove the build-up in the crevices. Then brush it all out with an old toothbrush or similar.
Clean it thoroughly and it will fix your problem
Posted on Nov 15, 2010
brector3
  • 1602 Answers
SOURCE: The shaving screen pops up when I turn on the
If you require a new screen for your shaver, you will find at shaveroutlet.com. See link below http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
Posted on Nov 26, 2010
brector3
  • 1602 Answers
SOURCE: The red light showing the shaving head remains on
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on Dec 01, 2010
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Should I shave with or against the growth of my hair with an electric shaver?
When you use an electric shaver you can shave either with or against the growth of your hair. In case you use a rotary shaver, you should make small circular motions with the shaver head on your face, do I gently, let the shaver do the work for you. If you have to press down hard in order for the shaver to cut your shaver is dirty and needs to be cleaned.
Feb 06, 2013 | Health & Beauty
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
Shaving with an electrical shaver is considered to bet wet or dry shaving?
Most electric shavers are dry, meaning that you don't need any gel or a shaving cream in order to shave although there are some unique wet electric shavers' models on the market.
Why is my andis t out liner not cutting nice and clean
You need to have your Andis T sharpen and adjusted for power, Check out Manny's Sharpening for their mail order service on sharpening. Manny's Sharpening specializes on Andis T-Outliner.Manny's Sharpening They will hook you up on that T, You can request on how you want the blade set for Line Ups or Fade cuts and even shave. They do it right Manny's Sharpening been around for over 20 years and they have a good rating on the net.Andis T Video
May 13, 2011 | Andis T-Outliner Hair Trimmer
My andis trimmer is not giving a very close shave. I like to have sharp line-ups. How do I fix it? I'm not sure of the model, but I'm using the website where I bought it as reference(...
This Andis model is not very good for shaving,I purchase one before didn't do the job. I recommend The Andis GTO you can have it sharpen and adjusted to shave. check out www.mannys-sharpening.com I had purchase my Andis T-outliner service and adjust for shaving. The good thing about manny's sharpening when you purchase Andis T-Outliner he will ask you how would you like your trimmer set at' for line ups or Fade cuts or Shaving set. he resharpen the blade and make sure the trimmer is adjust power and set blade and trimmer too your request. You may pay a little more but it's worth it. Oh one more thing about his service and warranty after 3 month he gives you a free sharpening and service on the Andis trimmer you purchase from him. You only paid for return shipping. I try his service and this guy is good in sharpening and repair. I hope this was help for Tim
Nov 10, 2010 | Andis Outliner II Hair Trimmer
Cant shave well
Check the blades. They should be brushed clean after every use. Possible that the blades are worn out.Replace them. Also, could be that that power is not enough. Check the cord and the connection.
May 22, 2010 | Andis 04603 Hair Trimmer
Is the Braun Activator8595 a good shaver for extra sensitive skin
The Braun foil shavers are well designed and I find they work well for sensitive skin if you prepare properly. Make sure you apply a hot towel to your face followed by a shaving conditioner. When applying the shaver, press lightly. Don't be afraid to go over the same areas several times to get most of the whiskers. Once you do this for about a week, your skin should begin to adapt to the sensation of electric shaving. You'll then be able to use the shaver more aggressively and get a thorough shave.
Apr 04, 2010 | Braun 360° Complete 8985 Electric Shaver
Clippers for a chow chow
google your city and grooming tools repair shop. then go there tell them your dog type and they'll recommend the best clipper for your dog. I suggest sticking with andis or oster  brand clippers. But be advised, pending on your sense of humor dogs dont like to stand still!!!!
Mar 23, 2009 | Health & Beauty
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Health & Beauty Logo
24 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
