Question about HP LaserJet 1100 Printer
Printing issue I have a HP 1100 hooked up to my workstation. In order to get my printer to print, I have to unplug the power and plug it back in. It will print the rest of the day but I have to do the same process every day.
  • 39 Answers
The printer is in sleep mode. You should be able to press the GO button to bring it out of this state and the printer should then be in READY mode.
Posted on Nov 02, 2007
Hp laserjet p2055dn blank display
Similiar Blank Display solution from HP web site:
HP LaserJet P3005 Printer Series - Blank Display
ISSUE: Printer has a blank display.
Check if the printer is connected directly into a wall outlet. If not directly connected, power off the printer and connect directly to wall outlet.
Disconnect any local or network connection from any device and keep the printer connected with the power cord cable.
Power cycle the printer. If the issue persists, continue with step 4. If the printer powers up to READY, perform the following steps:
Print a configuration page and check the firmware version. If the printer does not have the latest firmware version, upgrade the printers firmware. Click here to see the latest firmware available for your printer at . Select Download driver and software (and firmware) and type in the product name or select the product from the product category list.
When the firmware upgrade is completed, power cycle the printer and print a configuration page again and check firmware date code, (it should change to the latest version) then power cycle the printer again.
If the printer powers up to READY, plug the local or network cable back in and print a Windows test page by printing from any application.
If the issue persists, continue with step 4 below.
Remove any additional memory DIMM installed (usually the LaserJet P3005N, DN and X come with a 32 MB memory DIMM installed), and any Internal EIO card or internal hard disk installed and then power cycle. If the issue persists, continue with the next step.
Perform a cold reset:
Turn the device off.
Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
After the message SELECT LANGUAGE appears on the display, press the arrow up or arrow down buttons until COLD RESET is highlighted.
Press the check button. The device performs a cold reset and then continues its power-on sequence.
If the issue persists, continue with the remaining steps.
If the printer powers up to READY, test the printer functionality by printing internal pages. Plug the local or network connection in and test the printer from the workstation.
If the issue persists without any internal device installed, the printer will require service.
Contact HP support.
Click here for information on contacting HP support at
HP LaserJet P3005 Printer Series Blank Display
Apr 09, 2016 | HP Office Equipment & Supplies
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
Printing Stalled with flashing exclamation light
do a powerflee
1) unplug all cables including power cable.
2) press and hold the On/Off button on the printer for 20 seconds.
3) plug back the cables and try printing.
May 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Why is there a flashing orange light on the front of my printer ? and where it used to print it does'nt now ?
Switch off the printer and unplug the printer cable from both ends ( printer and computer ) wait for 5 seconds plug the printer cable back, switch the printer back on try printing, you can try printing hardware test page from printer to check the printer.
Sep 25, 2009 | Office Equipment & Supplies
Duplex printing
On the workstation go into Control Panel, select Printers, highlight the proper printer, Right Click for secondary menu and choose Properties.
Select Device Settings tab, look under Installable Options, Click on Duplex Options field and select proper setting.
This may differ from printer makes and models.
Feb 17, 2009 | HP Color LaserJet 5500hdn Printer
My printer is printing doument very small and colorslike blue,ect; want show on paper at all. I can find how to set it to just plain printing , could I get help Please HP Officejet J5780 All-in-one ...
Perform a reset of the HP All-in-One
  1. Press the Power button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the unit.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the unit.
  6. Plug the power cord into the wall outlet.
  7. Turn on the unit by pressing the Power button.
  8. Follow the instructions that display on the HP All-in-One to select the settings.
or if its software related:
the easyest way is right from here click on file on the top left goto page setup in the drop down menu.
paper size should be letter
on the bottom right of that you will see 3 tabs |ok| |cancel| and |printer|
Click on the printer tab and then another window will open and click on properties this will bring you to yet another window but the one you will need to be in to make sure all is correct with your printing software.
ushally there is a default setting there as well this ushally fixes the issues with the software end reseting it back to normal.
accept and then reboot your computer just so all changes are locked in and then plug the printer back in after the hard reset and all your issues should have been soloved.
hope that helps let me know how you made out.
Aug 02, 2008 | HP Office Equipment & Supplies
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
HP LaserJet 1100 Printer Logo
79 people viewed this question
Ben Johnson
