Question about Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included
Quickie s-11 won't power up - Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
I need an owners manual for a quickie asprie power wheelchaie
you can get it from the manufacturer's webste or by just searching google.
Apr 07, 2012 | Quickie Wheelchairs Quickie Aspire Power...
When i press the power button the lights on the joystick go up down twice then blinks real fast this is a f-11 quickie i could really use some help right now thanks
The F-11 Quickie usually came with a VSI controller (joystick). You can go to the following link to determine your problem:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Penny and Giles, the manufacturer of this control gives some suggestions to diagnose the problem.
If you post with more specific information and some history such as age of unit, serial number, rehab seating or controls, tilt etc., I can give you more specific information.
The most common problem of the this chair relates to the large plug at the end of the VSI harness at the rear of the electronics tray. Unplug the large connector (9 pin) and the small connector (3 pin). Inspect for dirt and corrosion, discolored pins, and loose connections. Clean the connectors with spray electronic cleaner and the large pins (9 pin connector only) with a green synthetic scour pad (use a soft touch if gray and burnt). Clean and allow to dry before assembling. Hope this helps.
Dec 11, 2010 | Health & Beauty
Trying to obtain a manual for a power chair, Sunrise, Aspire Quickie?
lundsuzy goto: sunrisemedical.com At the home page in the product search box in the upper right type in "Aspire". When that page comes up click on view details then the next page will list owner's manual there your manual will come up and you can print it
Sep 17, 2010 | Quickie Wheelchairs Quickie Aspire Power...
After two or three minutes of travel, the power
You got some bad batteries or your charger is not working. If Medicare purchased the chair contact Repair Xpress at 1-877-581-3733 Medicare will pay for most of the repairs
Jul 25, 2010 | Quickie Wheelchairs Quickie Aspire...
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Do they still make the Aspire Power chair ?
You can still get parts. The Aspire is an older model though
Jun 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
Apr 12, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included Logo
333 people viewed this question
Top Quickie Wheelchairs Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Quickie Wheelchairs Furniture Expert? Answer questions, earn points and help others
