Question about Gb Electrical Electrical Supplies
Wire diagram sr4b 380 - Gb Electrical Electrical Supplies
Wiring diagram for Pioneer mvh-x381bt
http://www.crutchfield.com/S-7avRLcyQAJR/p_130X380BT/Pioneer-MVH-X380BT.html
scroll down the page to the owners manual link. It has the wiring in it. The 380 is the slightly older model but all the color codes of pioneer radios use the industry standard colors.
Aug 12, 2016 | Pioneer Car Audio & Video
Wiring diagram for Cocao-Sox Covert Spy Hidden Hat Camera.There are three wires that are attached on the large PC board with a Large IC and next to it there is a smaller IC there is also a heat sink...
Since you have meter, check for this:
Red is mostly used for supply voltage; likely 5VDC.
Black is mostly ground.
Blue is often used for a switched supply line.
Good luck-
Dec 25, 2014 | Televison & Video
Where can I find a wiring diagram for a gardena 380 ac mower please?
http://nickviera.com/electrical/lawn_mower/bandd/mower_wiring_diagram.png
Oct 21, 2014 | GARDENA Garden
I want to locate the turn signal relay for a 1982 mercedes benz 380 SL
I am not sure there is a relay for the turn sig. Relays are for large current needs like horns and headlights. If you mean the flasher it should be under the drivers kick area, a 3 prong silver job. Google the wiring diagram and if there is a relay it will be on the pos leg probably red wire.
Sep 30, 2014 | Vehicle Parts & Accessories
Fuse box location mitsubishi 380 2005
hi
the first internal fuse box on a Australian 380 Mitsubishi is located on the drivers right side end of the dash.
open the drivers side door and on the right end of the dash, you will see a panel that sits flush on the end of the dash.
pry the panel open with your fingers or a tool, it opens up to the right, there are relays and fuses in there for the cars different functions.
the 2nd fuse box is located under the hood/bonnet on the Australian 380 model.
if you are in front of the car looking at the windscreen it is located on the right side in a black box near the suspension tower.
the top pops off and relays and fuses are in there.
both fuses boxes have the wiring diagrams under the lids so you can identify which fuse operates which function
to match the fuses to the diagram, start from one end first and check the amps for that fuse then the next one in the same row and then the next one.
after that you should be able match the fuses to the diagram, if the fuses dont match the diagram from that end, then start at the other end and do the same thing.
i hope this helps
cheers
Jul 23, 2012 | Mitsubishi Cars & Trucks
Unit floats does not run on all wheels
Sounds like it might be missing the head weight. Check for number 25 in this Polaris 380 Parts Diagram
Jun 28, 2009 | Polaris 380 In Ground Pool Cleaner
Electrical Supplies Logo
24 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Steve
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
