Question about Games
Trileaf distribution trifeuil - Games
How to fit a morris minor distributer
Hi The distributer should have an offset drive so it can only go back in the same way it came out,
As to no spark:
Check the contact points
Condenser
Tiny earth wire from breaker plate to distributer body.
Coil
Ignition supply and ballast resister.
Morris cars originally had a positive earth system on the battery if you change to negative earth you must check the coil connection the Neg - terminal on the coil goes to the distributer and the Pos+
is ignition supply
Apr 16, 2014 | 1969 Morris Minor
Leak under distributer
The most common cause is the heater hose coming off the head, below and behind the distributer. Usually the distributer is leaking oil, which gets on the hose and damages it. If you don't fix the oil leak, which could be the distributer "o" ring, (inexpensive) or the distributer shaft seal, (expensive) cut a piece of the old hose and use it to protect the new hose from the oil.
Apr 12, 2014 | 1998 Honda Odyssey
Check and replace the bulb. Make sure your charger has power coming out of it. Also, depending on how long you have owned this the battery could be shot. Just as cheap to buy a new light as it is to buy a new battery.
Jan 11, 2014 | Vector 2M Pwr Rch Spotlight
Maybe you should ask in a different section. This one is for computers. Or you could ask at the place where she bought it.
Jul 10, 2013 | Computers & Internet
How to put in a distributor in a 88 chrysler conquest
Make sure the timing mark on the harmonic dampner is at tdc. drop the distributer in the hole so as the distributer gear engages with the cam gear , it will rotate slightly. You want the rotor to end up lined up with the number one spark plg wire position on the distributer cap. If the car doesn't fire and you are sure you have power to the distributer, then you will need to pull the distributer out and turn the rotor 180 degrees and reinstall. The motor should then fire.
May 12, 2011 | Chrysler Conquest Cars & Trucks
What are the steps to follow when youre going to install a 1991 Toyota Camry 2.0l Distributor,
Take the screws out of distributer cap, mark exactly where the rotor is pointing with paint pen on distributer cap and distributer. Loosen bolts holding down distributer. Lift out distributer after you unplug electrical wires. Place new distributer in place making sure rotor is pointing to exact same place where the old one pointed. Replace distributer cap and electrical wires and your done, try to start the car.If car starts your ok.If it doesnt start andd backfires it means rotor is in wrong place,take back out and restab it.good luck
Sep 25, 2010 | 1991 Toyota Camry
Does the 2006 dodge magnum have more than two sets of fuses?
THERE ARE JUST TWO.
Power Distribution Centers/FUSE BOXES
1. Front Power Distribution Center
A power distribution center is located in the engine
compartment. This center contains fuses and relay
2. Rear Power Distribution Center
There is also a power distribution center located in the
rear compartment under the spare tire access panel. This
center contains fuses and relays.
Opening The Access Panel
Rear
Jun 04, 2010 | 2006 Dodge Magnum
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
1985 4100 distributer shaft problem
Sounds like the clip came off the shaft and it fell inside bock. Get a new distributer and get number one cylinder up on compression stroke and drop distributer in pointing rotor at number one on distributer cap.
Jul 05, 2017 | 1985 Cadillac Eldorado
Games Logo
91 people viewed this question
Top Games Experts
Lesley Cameron
Lesley Cameron
Pamela Leach
Pamela Leach
Are you a Game Expert? Answer questions, earn points and help others
