Question about Hardware & Accessories
Handle moves but won't retrack latch
Adams rite hardware the inside paddle moves but will not open door
pittmanc
  • 194 Answers
SOURCE: Drivers door latch won't open
your latch has cam loose from the lever you need a repair manual this will tell you how to remove the latch then there will be a plastic clip you will need to replace fallow all instructions and this will be an easy fix **but make sure door is open when you do this***
Posted on Dec 05, 2008
  • 88 Answers
SOURCE: 1999 BMW 323iS drivers side door. I cannot open
you are correct they are flimsey and get fatigued with age easy to replace harder to find
Posted on May 20, 2009
  • 159 Answers
SOURCE: unable to open driver side door with inside latch
take the bezel off around th door handle. take the screw out of the armrest. pull out the window switches and pull out on the door handle and pull up .disconnect the last two plugs then you can see the whole door handle
Posted on Jun 04, 2009
ghost4548
  • 776 Answers
SOURCE: driver's side door latch wont open door from inside
Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Posted on Jul 18, 2009
BuzzFlewhart
  • 655 Answers
SOURCE: The drivers door will not open from the inside.
Linkage has become detached. You'll have to pull the door panel. There are steel rods (linkage) that are held in place by a PLASTIC CLIPs (GM's better idea)... The clips break or come loose. Replacements are available at GM dealership but you'll need to figure out which one is bad. Take the old piece (or pieces) along with you so you can make sure you are getting the right ones. The interior handle and the exterior handle are on two seperate mechanisms which is why the inside doesn;t work yet the outside does. Hope this helps. Good Luck. If you need help figuring out How-To remove the door panle, a trip to your local public library in the Automotive books section should help and show you how the panel pulls off. A panel removal tool is a big help and is available at most Auto Stores. You make end up breaking someof the plastic clips that hold the panel in place but they are available at an Auto Store also.
Posted on Dec 16, 2010
I bought a Stanley Screen & storm knob door latch recently (74-8258). The "spindle" connecting the inside and outside handles seems to "float", i.e., not be anchored in place. It seems that with repeated...
If the spindle is installed correctly, "floating" does not hamper proper operation. Review your installation and make sure the floating spindle is properly sated in the handle and alignment is maintained during the tightening process
Sep 03, 2013 | Stanley Hardware 748257 Black Screen &...
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
2006 Chev Impala - back driverside door won't open from inside or out.
take the panel off the other side door and have a look and compair the two, though there is a small part between the two mechanisms that maybe missing
Jun 11, 2012 | 2006 Chevrolet Impala
Door will not latch on 1990 cutlass ciera
The door latch paddle latch spring is broken, you will need to determine the door and replace the door latch assembly.
Please rate my help for Fixya, it improves my status and it is all I ask for my time helping you with your problem. Thanks
Jan 18, 2012 | 1990 Oldsmobile Cutlass Ciera
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
1972 corvette stingray, driver side door does not open fron either inside or outside.
Sounds like the door latch mechanism is worn out.
The door latch mechanism for your door is operated by rods, from the inside door handle, and the outside door handle.
It is highly unlikely, (Though not impossible), that all those two rods have fallen off. (Spring clips hold the rods in place. Opening Rod Control Clip. In the link below they are shown as Item E)
With the window all the way down, carefully use a long flat tip screwdriver, to push down on the lever for the door latch mechanism, to open the door. Make sure the lever for the door lock, in the door latch mechanism, is in the fully unlock position.
This link may help show you the inner door hardware, I'm referring to above,
http://www.mamotorworks.com/corvette-c3-door-hardware+1968+1982-inner-1-106-9491.html
You can see that when you pull out on the inner door handle, it pulls a rod forward. This rod is attached to a Bellcrank. The Bellcrank in turn pulls down on another rod, which pulls down on a small lever in the door latch mechanism, to release the door latch.
When you push down on the outside door handle, it pushes a small rod that is attached to that same lever as the inner door handle. Looking down through the window opening in the door, it is that lever that you're trying to push down, to open the door.
Viewing down through the window opening, try to operate the outside door latch a little. Watch to see what lever it tries to move. That's the lever you have to move Down, with the flat tip screwdriver.
With the door open, it is a matter to check out,
1.The Inside Door Opening Control, (The inside door handle is attached to it), to see if the locking part of it is functioning correctly. Make sure that it goes to the full Unlocked position.
2.The Door Latch Mechanism. Make sure it is functioning correctly. It, along with the various door hardware parts inside the door, needs to be lubricated at specific intervals. The more it's used, the higher the interval rate goes up. (I find that owners seem to Skip this task a lot! I use Lubriplate White Lithium spray)
To replace the door latch mechanism, I suggest you buy a manual for your car, so you can view all of the door hardware to remove, to remove the door panel. Then view how the spring clips come off of the rods, and the three screws come out of the door latch mechanism.
Jul 12, 2009 | 1972 Chevrolet Corvette
1997 F150 Pickup door wont open
I believe there is a cable which connects the handle to the latch, they are pron to breaking.
Jun 21, 2009 | 1997 Ford F150 Regular Cab
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Both front doors on my "93" Corsica won't open.
You have to open the Window all the way And I Assume your looking Down Threw the Glass opening to View the Linkage,
their is a Spring for the Return of the latch, While looking at the Latching system, Look for the Spring that When you "Try" to open the Door it's Suppose to Compress, Most likely the Spring is Not Fully Releasing,
You may try WD40, And work the handles for a few mins and Then Try to Unlock the door for it to open, OR you can Try a LONG Screw drive to Slide the Spring to fully Non compressed state and then Make sure the Door Lock is in the Open State before you try the handles..
Feb 03, 2009 | 1995 Chevrolet Corsica
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
