Question about Kitchen Ranges
Roper s9507x2 oven shuts off at start of preheat
Won't stay on
SOURCE: Roper stove/oven range
need a solution for this problem
Posted on Sep 04, 2007
jumptrout51
  • 3361 Answers
SOURCE: can not get oven door back on my Roper oven
With the door on a flat surface.
Open (extend) the hinges and insert a small nail or pin in the holes in the sides of the hinges.
Then put the door on and remove the nail.
Posted on Mar 04, 2009
  • 62 Answers
SOURCE: Why won't my roper gas range (FGS337KQ) stay lit?
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: The oven shuts itself off after preheating.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jun 07, 2010
  • 5370 Answers
SOURCE: Oven will shut off by itself. This has occurred
Its the problem with bake ignitor, it has to be replaced. Pretty easy, remove the floor, after unplugging, then 2 screws and 2 wire connections
Part cost is around $40 to $75 and is held in with 2 screws for the most part on these ranges. takes all of 25 minutes , only a screwdriver and a 1/4" nut driver is needed for it's replacement.
you can get required parts from sears online parts site or from repairclinic.com ------------ Also check this link for more help:--- http://technoanswers.blogspot.com/2011/06/maytag-mgr5750-gas-kitchen-shuts-off-in.html ------------- This should help.thanks.Helpmech.
Posted on Jun 17, 2011
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
Shuts off druing preheat
Either the thermometer is sending the wrong signal to the logic board on the front panel or the thermostat that regulates is the problem.
Jan 22, 2013 | Ovens
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
Jan 19, 2007 | Roper FEP310 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
