Question about Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential
New batteries fully charged for go go elite when put on scooter will not light above one yellow
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Battery not charging fully go go elite scotter
hi, And you're sure the charger's okay ? , check the fuse located within the battery pack ...
Regards
Rob
www.gewizrepairs.co.uk
Nov 24, 2013 | Pride Mobility Products Go-Go Elite...
When first purchased the scooter was charged but barely used for approx. 3 months. when we began using it regularly the first two charges lasted for a weeks use each. from then on the red charge light goes...
Well if the scooter wasn't charged regularly while it sat for 3 months then the batteries are probably weak and will need to be replaced. These smaller batteries will not tolerate not being charged regularly and unfortunately one or both batteries has gotten weaker and does not hold a charge like it should when new. Sorry i can't give you a better answer Remember to charge the new batteries before use and if you are not using the scooter regularly (daily) always put up fully charged and charge at least once a week. If you use it daily charge the scooter when you go to bed and unplug when you get up in the morning. If you do this you should get good use out of your batteries. Hope this helps
Mar 19, 2011 | Pride Mobility Products Go-Go Elite...
MY scooter battery needs recharged and I plugged it in and it indicatied it was fully charged and it wasnt. So I bought a new charger and that is showing the same thing. I dont know what to do next. The...
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Oct 12, 2010 | Electric Mobility Health & Beauty
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
Oct 04, 2010 | Pride Mobility Products Go-Go Elite...
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
We have charged the battery and when we turn on the scooter all it does it make a beeping sound and the scooter will not move
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Jun 12, 2009 | Pride Mobility Products Go-Go Elite...
My go go elite Scooter will not work. its only just over a year old. it's not been used for a few months. When put on charge the charger shows its fully charged. When the scooter is swithched on the volt...
It may still be under warranty.  What kind of reading did you get from the batteries? If they are below 12.0 volts they may have a poor memory. If you leave a chair un-charged for a long period of time the batteries can discharge to a very low level. The charger cannot bring a battery up from 11 voltsDC. You will need a slow car type charger or new batteries.
Mar 19, 2009 | Pride Mobility Products Go-Go Elite...
Open Questions:
See all Invacare Supply Group Invacare Scooter Lynx L-3 Questions
Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential Logo
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
