Question about Cooktops
Miele FE 31 - Cooktops
How do i find instruction manual for miele hob
Many times if the unit is OLD they drop them from the list
Apr 01, 2016 | Miele Cooktops
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
Replacement glass top miele KM5773 36
THERE ARE SEVERAL WEBSITES SELLING MIELE
parts: Search them and contact them:
Technical Service
Miele Parts Partmaster
Find Miele Spares and Accessories
Accessories
Expanda your search with google, use terms
MIELE PARTS
Apr 10, 2013 | Miele "KM5773 36"" Ceran Glass Induction...
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
I have looked all the site for MIELE parts, but non of them carry miele. Where can I buy ignitor of this cooktop? thanks
you can only purchase Miele parts from Miele and no one else other than authorized Miele service agents and it is the same price. you would also have to call them as parts are not on line
Aug 15, 2010 | Miele 36 in. KM3474 Gas Cooktop
Miele gas cooktop flame shuts off after lighting. If I keep the button down longer to allow more gas to flow to the burner it will stay on.
I had similar problem.Solved by Miele tech by placing rice grain sized wad of paper towel inside knob so it sits slightly higher on the valve shaft.
Oct 05, 2009 | Miele 35 in. KM391G Gas Cooktop
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
