SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
SOURCE: Calculator paper roll change, How to?
feed paper throught bottom to top hold down paper feed botton
SOURCE: I have a sharp calculator EL-1801V...that I need
hello. here you go. here is the entire owner manual for your use.
http://www.sharpusa.com/files/cal_man_EL1801V.pdf
SOURCE: How do I change the date on a Sharp EL-1801V
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
