Question about Microsoft Xbox 360 Console
Does my 360 have a disc drive issue?
My disc drive is wobbly. It shakes around a bit if i move it and it feels loose, also...
My 360 seems to be lagging like crazy. For example, when I play Fallout 3, the game lags like crazy. One second it will play normally, then the next it will take 5 seconds to work slightly, and it lags for a few seconds, then works well for a second or two, and repeats. I also hear a noise where it seems like the game is being read, then stops being read, then starts again, and stops, like it may be dying. Also, it seems to take longer to get mandatory updates and sometimes freezes while trying, and games have froze, especially when I press the guide button in the middle of the controller.
  • Jonathan Soules May 11, 2010
    first off... have you gotten the rrod? (red rings of death) because if not, then it may be your graphics card acting up while you play. I doubt it's your disc drive that is messing up your game. does your game disc get scratched at all when you take it out? like with little circular scratches? if you do have a problem with your disc drive I'd recommend sending it in to microsoft to fix it, cuz disc drives can be quite touchy....
    Problem Solver:
  • 10 Answers
The lag you're experiencing most likely isn't the result of any physical abnormality, but rather you're network. How many people in your household share the same network? The more people on a network, the slower it will run. (I've actually experience this first hand) You might have too much people sharing your network for your game to run smoothly. Try to go on hours that everyone is not on. As for the repeated starts and stops, during game play, don't stress that. Its normal.
Posted on Jun 20, 2009
2 Suggested Answers
geo_jonas
  • 555 Answers
SOURCE: Do I have a disc reading issue?
try to clea the Disk that you are using then try also to insert other disk that is working to check if the problem is the disk itself. Only then if the result is the same then the problem would be either the Player hardware or the Support software maybe its corructed or not compatible to the disk you want to insert. Then if the hardware has a problem contact the PS3 repairshop in your place. But if the support software has the problem then you can update it or reinstall your software support in your PS3.
Hope it helps your problem.  If you need more assistance just conatc me or reply to this post.  Thanks you
Posted on Jun 19, 2009
Terrible shake and clunking noise ONLY in 4 wheel drive/auto ;coming from rear of vehicle.
Rear ujoint may be bad causing vibration when under load from transferring. Also could just be loose or bad carrier bearing.
Dec 13, 2017 | Cars & Trucks
When driving around at any speed on highway my car feels like gliding It feels like I'm going to lose control and sometimes when I brake coming down hill the front end shakes violently. then will stop
This is an indication of a strut issue. The shocks dampen the spring in the strut assembly. IF you have loose fastening components or bushings or a bad shock in the strut you can get a violent shudder when you apply brakes on a down hill direction.
Sep 21, 2016 | Cars & Trucks
Car vibrates when idle
One or more of the following may be the cause:
1. One of the cylinders is not firing properly, causing the engine to shake, which is more noticable at idle speeds. This is unlikely to be the cause though, since it would cause your Check Engine Light to come on.
2. Something ON the engine is loose or unbalanced. Lift the hood and look at the belts - particularly the pulleys that they go around. Keep you hands out of the way, but use a flashlight to shine on all the pulleys and look for any wobbles. The one that would have the biggest impact would be the one at the very bottom of the engine. Even the slightest bit of wobble can really shake the engine. A wobbly pulley could mean that it is loose, bent (unlikely), or that the bearing that makes is turn smoothly has been damaged and now allows the pulley shaft to move. This is mechanic territory.
3. An engine mount has weakened or torn loose. Your engine isn't attached to the car with solid bolts. There are special pieces of rubber in the place where it attaches, and these can erode over time - or even tear and rip if the engine is powerful. You can test for this by looking at the engine and having a friend put their foot on the brake and then shift from park to reverse to drive, and then back to reverse. If the engine rocks by more than 1-2 inches, it is possibly a damaged engine mount. Again, this is mechanic territory to get fixed.
Good luck!!!!
Apr 24, 2014 | 2007 Dodge Nitro R/T New Cars
Driver side wheel shakes often. I changed brakes and rotors and problem continues. What is the problem.
I would call this 1 of 3 possible problems.....
This first could be a bad or unbalanced tire. Sometimes the multiply ties we use on cars separate between layers, this causes an un-natural bulge that can not always be seen, but certainly can be felt while driving. This is called ply separation. An unbalanced tire, which could be caused by a wheel weight falling off, or a shift in weight that could be cause by something like an impact break or the ply separation, would also cause a wobble that varies at different speeds. The best way to check it out without a shop visit, is to take the wheel off and just inspect it, make sure everything is smooth and even.
Secondly, a wheel bearing could cause a wobble as well. The self test for this is to jack the car up, leave the tire on and wiggle it. It should feel tight all the way around and not move up to down, or side to side. A way to test this unit while driving, which is not always accurate 100% but will give you a clue as to where to look first is drive in an area free from other traffic, when it starts to wobble, turn to both the left and right without touching the break. If the wobble goes away it is likely the cause.
Thirdly the ball joint could also cause a slight wobble. To check this, I usually jack the car up, do the same wobble test as described above, then remove the tire and inspect the joint. A good joint will have absolutely no tears in the boots. It should also feel solid at you try to move the other components that surround them.
Good Luck, we are here if you need anything further.
Mar 25, 2010 | 2000 Chrysler Concorde
Scracthes rings into the game
Lay the Xbox horizontally on a very sturdy surface. Scratch rings often indicate and Xbox and shaky surfaces ie: floor, wobbly shelf... Walking around and stuff like that can shake the xbox and rattle the disc around inside.
Oct 02, 2009 | Microsoft Xbox 360 Console
Scratching disks
Microsoft have changed the mould for the dvd trays (or the suppliers have changed them at least) so that on the latest editions of the 360 it does not scratch them as much as it used to. the previous person is right. what happens is that when the disc is being read from it will spin very very fast and one slight knock on the older 360's would produce a ring right around the 360. this happens when the game disc wobbles and touches the moulding on the dvd tray.
i would try not to move the console while its on, wait at least 30 seconds before moving the console after you turn it off.
if you have a wired pad this can make things worse as everything you pull the pad it can make the disc wobble and cause this problem.
a friend of min stopped this happening by getting a thin enough peice of soft foam and gluing it onto the tray so that when the discs did wobble they would skim the soft rubber and not the hard mouldings.
im also guessing its a samsung drive you have because the earlier ones were really bad for this.
hope it helps a bit.
www.fixmyconsole.co.uk
Jan 30, 2009 | Microsoft Xbox 360 Console
Magnet issue?
No the thing on top is supposed to move. It sounds like eather a scratched disc or you need to clean the laser lens on the drive.
Jan 19, 2009 | Microsoft Xbox 360 Console
Ring around disc
This is a design fault on the 360 itself. You need to make sure that the Xbox 360 is NOT moved while the machine is switched on. You need to make sure that the xbox is secure and connot move because of vibrations.
When it is moved the vibration of the move causes the disc to wobble and comes into contact with the drive plastic underneath which causes the ring round the game.
Jan 02, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
115 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
