Question about Toshiba CT-90326 Remote Control
Cannot find AV for wii
What channel do I put my wii on?
Connecting wii
Either the AV channel or Component Channel depending on where you have hooked it to the TV.
Nov 05, 2013 | Nintendo Video Game Consoles & Games
Hi i have a very old panasonic tv and when i install the wii there isnt a tv/input button on the remote
Try going down through all the channels. The older tv's usually kept the AV channel before channel 2.
Jun 21, 2010 | Nintendo Wii Console
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Trying to set up Wii console with Hitachi 42PD580DTA, but there is no AV channel so what do you switch to when trying to operate the Wii?? where do I put the cables? sooooo lost??
You should have various input connections on the back of the tv. Use the red, white (audio) and yellow (video) connections. The remote should have a button that lets you select which input to use. After connecting the wii, turn it on and try all the input selections until you see the wii screen
Dec 23, 2009 | Televison & Video
What channel do I put it on to play the wii if I have attuverse tv
connect your wii and then click on the tv/av button on your tv remote...try twice or thrice it should start working
May 21, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Mar 07, 2009 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Wii
You tv needs to have av plugs. Yellow for video in Red and White for Audio in. These need to be in the "in" ports. then you can turn to the right av channed it should be before channel 2 so just keep going down. If your tv has more than one set of av in ports there will be more than one av channel below channel two.
Aug 01, 2008 | Sanyo DS31520 31" TV
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
Finding the correct channel on the TV for Wii
ok. push tv video button on your tv,
or
first turn on your wii, be sure that the av cable are connected to ur televison properly. Then turn on your tv start from channel 1 then scroll down the channel button until you locate the blue screen or logo of wii.
Jan 24, 2008 | Video Game Consoles & Games
Toshiba CT-90326 Remote Control Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
