How do i take the carburetor off of a honda ew140 welder?
I got everything off of the carburetor and there are no visible nuts, bolts or screws holding it on, but it still wont budge?
blueextc3221
  • 15935 Answers
SOURCE: Problem installing new toilet bolt covers.
unthread the nut as far as possible, then tighten it one full turn. Cut off the top with a hacksaw or dremel grinder and re-try. The bolts are cheap. A small jewelers file may help. Look for the damaged thread and remove the burr.
Posted on Dec 22, 2008
SOURCE: rav 4 2004 tail light replacement
There are 3 bolts & a push stud with a plastic cover. The two bolts hidden by the trim are more easily accessible with bulb holders removed. I would also suggest something to catch any falling nuts would be a good idea.
Regards
REM
Posted on Jan 29, 2009
joecoolvette
  • 5660 Answers
SOURCE: How to loosen screws to remove blades from Ozito OZPL400A planer
WD-40 is nice for some situations, but not this particular one. I suggest you use something like Liquid Wrench. Apply, tap the nuts on each side with a metal punch, and a very small hammer. Not hard! You're just trying to bust any rust loose, and give the liquid wrench a chance to ease down in there.
Just tap!
How are you holding the bolt head on the other side? If these nuts are so corroded that this method won't free them, you make want to see if a 1/4 inch air ratchet wrench is available. The wrench is shaped in a 90 degree angle, so it should fit down in there. Have any mechanic friends? The bolts may break. It may come to this. Be sure the bolt head is held secure, so that no damage will come to the planer. If they, or it, breaks, you can just replace them. Make sure they're Grade 5 or above, bolts and nuts.
I've had to use a small propane torch to heat the nuts. The rust breaks free. I hope it doesn't come to this.
Posted on May 10, 2009
SOURCE: The 15/16 nut that holds the blade on is locked tight.
Had the same problem with my mower. Find a length of metal pipe that will fit over the handle of your socket wrench and it will give you more torque. The nut on mine would not even budge with a 12" extension bar, but when I put a 3ft steel pipe over the bar, it popped loose with very little effort. I also used a wood block to hold the blade tight
Posted on Jul 20, 2009
harlan301
  • 205 Answers
SOURCE: Trying to remove sterring shaft screw under the body
the screw has lock ty-et and yes its a pain we run in to this all the time just keep trying or heating it up helps most of the time we cut them out. you'll have to remove the deck. when we reinstall we put a bolt head type back in. good luck
Posted on Oct 13, 2009
How to adjust a clutch on a 83 Honda 250 dirt bike
IF CABLE, loosen the lever end right off, then remove the engine cover where it enters, a 10mm nut will be visible, and a flat screw head, use a screw driver to hold it tight, and 10mm to slacken the lock nut, using screw driver tighten to just a stop, then loosen quarter a turn, lock 10mm nut, keeping flat screw driver holding the head tight, same as any cable bike clutch.
Apr 05, 2015 | Honda Motorcycles
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Honda gx240 runs with choke on but when off it surges and I cannot get it to run smooth?
clean carburetor fuel jet and tube located inside the stem of carburetor removal of fuel bowl is recommended the bolt is a 10 mm and the same bolt screws into the stem where the jets are located,make sure all the holes are clear re install.
Aug 21, 2014 | Honda Electrical Supplies
How do i replace rear sprocket on honda trx 70
You will have to remove the rear left wheel, Then you will see two nuts threaded onto the axle. First back off the locking nut first all the way, then you can back off the other nut. There may or may not be bolts holding sprocket on. Be sure everything is put back on in correct order and tightened safely, as I have seen the nuts come loose and the sprocket slide off of axle creating a big problem when the chain hits the crankcase. Hope this helps
Jul 06, 2013 | Carburetor Sprocket Bracket Air Cleaner to...
1988 hurricane wont start cold
Instructions
    • 1 Lift the CBR onto its center stand. Unlock the seat latch with the ignition key and remove the seat. Remove the clip screws from the top portion of both seat rail covers, positioned below the fuel tank and the seat, using a Phillips screwdriver. Pull the seat rail covers away from the motorcycle's frame.
    • 2 Remove both bolts from the front of the fuel tank, using a socket wrench and a 10 mm socket. Lift the tank up and prop it open using the support rod on the motorcycle's frame. Reach under the tank and unplug the fuel pump's wiring connector and all three hoses from the bottom of the tank. Take note of hoses' locations before removing them for reinstallation purposes. Pull the hairpin clip out from the support rod's base. Unscrew the pivot bolt from the base of the fuel tank, using a 10 mm socket. Lift the fuel tank off of the motorcycle.
    • 3 Unscrew the air box's mounting bolt from the frame's right seat rail, using a 10 mm socket. Loosen the clamps securing the air box's flanges to the carburetors' inlets, using a Phillips screwdriver. Pull the air box towards the rear of the motorcycle to separate its flanges from the carburetors.
    • 4 Loosen the clamps securing the carburetors to the motor's intake manifolds, using a Phillips screwdriver. Pull the carburetors off of the motor and out through the left side of the motorcycle's frame. The carburetors will still be attached to the motorcycle by its throttle and choke cables. Loosen the choke and throttle cables' lock nuts, using a 10 mm wrench. Remove the cables.
    • 5 Hold the carburetors over a large container. Unscrew the drain screws on the side of each carburetor's float bowl, positioned at the very bottom of the carburetor, using a flat-head screwdriver. Allow the fuel trapped within the float bowl to drain completely, then tighten the drain screws.
    • 6 Flip the carburetor over, with the float bowls up, and place it on a clear work space. Unscrew the bolts from the float bowls, using a Phillips screwdriver, then pull the float bowls and their gaskets away from the carburetors.
    • 7 Unscrew the pilot jet from each carburetor, using a flat-head screwdriver. The pilot jet is placed to the left (with the carburetor facing you) of the main jet in the center of the carburetor. Screw a new pilot jet into place with a flat-head screwdriver.
    • 8 Reinstall the float bowls and their gaskets onto the carburetors. Tighten the float bowls' screws with a Phillips screwdriver. Reattach the throttle and clutch cables to the carburetors and tighten the cables' lock nuts with a 10 mm wrench. Slide the carburetors through the left side of the frame. Push the carburetors into the motor's intake manifolds. Tighten the intake manifolds' clamps with a Phillips screwdriver.
    • 9 Pull the air box against the carburetors and push the air box's flanges over the carburetors' inlets. Tighten the flanges' clamps with a Phillips screwdriver. Screw the air box's mounting bolt onto the frame's right seat rail, using a 10 mm socket.
    • 10 Lay the fuel tank onto the motorcycle's frame. Insert the tank's pivot bolt through the hinge at the base of the tank. Screw the pivot bolt's nut into place, using a 10 mm socket. Lift the tank up and reattach the tank support rod to the motorcycle's frame. Insert the hairpin clip into the support rod's base. Prop the tank up on the support rod. Plug the wiring connector into the fuel pump and reconnect all three hoses onto the bottom of the tank. Screw both mounting bolts onto the front of the fuel tank, using a 10 mm socket.
    • 11 Mount the seat rail covers onto the motorcycle's frame. Insert and tighten the covers' clip screws, using a Phillips screwdriver. Lay the seat onto the seat rails, then press the rear of the seat down until the seat latch locks into place.
Jan 14, 2013 | 1988 Honda CBR 1000 F
Miller welder starts fine bur appear to run out gas need help adjuting linkage to fuel control
you need to adjust the throttle governor on the side of the carburetor you will see a adjustment screw do a weld to get the welder to runs at high speed then adjust the screw till it runs continuously, if it still dies out change the fuel filter and try again drain the carburetor bowel if it's diesel replace fuel filter and run fuel threw the water trap.
Nov 18, 2009 | Welding Tools
Kickstand will not come off
Some times the bolt is screwed in and the nut is only there to keep the bolt from working back out.
Oct 06, 2009 | Harley Davidson XL 1200 S Sportster Sport...
When I give it a little gas the RPMs gradually increace on its own unless I rev the engine. Im lost
Suspect a weak throttle spring and maybe binding in the linkage somewhere. Check the foot-pedal bearing point for friction. Make sure the carburetor mounting bolts/nuts are tight along with the carburetor body screws. Check for leaking vacuum lines from the intake manifold and the carburetor.
Sep 26, 2009 | 1984 GMC K2500
Is there a lock nut holding the caliper bolts on a 2006 accord it looks like i need to get a second wrench to hold a nut while i loosen the caliper bolts.
its not a lock nut. Some cars have the retainer bolt screw into the slider pin. You will need a second wrnch to hold the slider pin as you unscrew the retainer bolts.
Jul 17, 2009 | 2006 Honda Pilot
Alternator lower bolt removal (1995 Honda Civic)
There is a nut back there that the bolt screw into it probably cam of the welding and is spinning around and and therefore would come loose just chock nut or use a wrench to hold and it will come out. Good Luck
Jan 05, 2009 | 1991 Honda Civic
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
