Question about Hisonic Ma222 Karaoke Mixer / Amplifier W/ 2 Microphone
Hisonic MA222 Karaoke Mixer manual instruction
Pv8 setup karaoke
Are you using a karaoke machine? Make/model?
May 03, 2014 | Peavey PV8 Mixer
How to use preset effects on 1002fx
I have answered this question in another post
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
Instruction booklets on machine
Many of the Singing Machine Karaoke system manuals are available on the company's support site: http://www.singingmachine.com/support/instruction_manual.php . The direct link to the STVG-1009 manual is http://www.singingmachine.com/download/Instruction_Manual/2010/CDG/STVG-1009/STVG-1009%20IM%20E01%20(SMC%20US).pdf .
I hope this helps.
Mar 24, 2012 | The Singing Machine Singing Machine...
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
Dec 09, 2011 | Behringer XENYX 2442FX Mixer
Trying to connect to a karaoke reciever
I don't know what you are trying to do but if you can plug ho! let say a CD player, than plug the KARAOKE machine in the same place...
Be more specific in your question pls...
Apr 10, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Humming noise since adding a vocopro DA-1050pro mixer to our system.Have connected a ground loop isolator but it makes no difference.The mixer is the only change in the system
Make sure ALL interconnected equipment is powered from the same receptacle or source such as power conditioner. This isncludes mixers, amps, CD pllayers, etc.
Second make sure ALL interconnecting cables are BALANCED lines using XLR or TRS cables.
Isolators other than DI boxes are a no-no.
Mar 30, 2011 | Vocopro Da1000pro Professional Digital...
Hope you guys can help... I have a laptop Karaoke system. I connect from laptop to 6 channel mixer to speakers. I use a stereo phono to RCA from laptop to mixer. I am experiencing a buzz coming through...
Yep! Get a decent audio interface that attaches to the PC with a USB connection and uses BALANCED lines to your mixer. I use a UA-25EX Roland/cakewalk as an example. (about $200 and there are cheaper units such as M-Audio Fast Track MKII ) Note these interfaces BOTH record and playback with two channels for stereo.
Essentially the audio board that is in PC's and Laptops are too near the switching noise of the processor and some of that is just bound to get into the audio lines as they don't even have balanced audio lines from the computers. Make sure you use either TRS or XLR balanced cables from whatever interface you get. Also connect ALL interconnected equipment to the same power source or receptacle. You can try to reduce the buzz with the mixer EQ's with what you have, but that sacrifices audio quality.
Mar 30, 2011 | AMP Speakers Pro Karaoke System
Hisonic Ma222 Karaoke Mixer / Amplifier W/ 2 Microphone Logo
77 people viewed this question
Top Hisonic Music Experts
Michial Gueffroy
Are you a Hisonic Music Expert? Answer questions, earn points and help others
