Question about Sharp 25J-M100 TV
Tv showing with lines, screen blank but hearing clearly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Its white retrace fault, check video section or crt internal short problem
Posted on Apr 29, 2014
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
I CAN HEAR WHAT IS SHOWING BUT CAN`T SEE IT.
Your vertical IC will need resoldered. And check near this IC for bad capacitors. And any and all grounds where there are heat sinks attached to other transistors and ICs. This should restore your TV. Find a hobbiest or TV tech to pull the board out for repair!
Apr 19, 2010 | Sony KV-13TR28 13" TV
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
My tv screen on my samsung rear screen projector has gone blank(black screen although sound is still clear.
Do you hear a motor spin up and a clicking sound as the tv is first turned on, if yes, You need to look behind the set and see if the lamp is still illuminated, if not replace lamp. Good luck.
Jul 07, 2009 | Samsung Televison & Video
My screen was showing lines in it and wouldn't
Try from that screen selecting Enabling VGA Mode.
Let me know
Jun 17, 2009 | Dell Latitude 120L Notebook
Vizio p42hdtv10a
Bad interface circuit or power supply. Needs servicing..
Jun 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
White lines
These are retrace lines. This may be a fault in the blanking circuits. On some occasions a weak CRT can also cause blanking lines to show.
This is something you would not be able to service yourself. I would suggest to have an estimate done on the TV set for you to decide if it should be serviced or not.
Jerry G.
Apr 07, 2008 | Philips Magnavox 27MS343S 27" TV
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
