Question about Standard Horizon Chart Plotter CP180 GPS Receiver
Tracks disappear after trip - Standard Horizon Chart Plotter CP180 GPS Receiver
Why are side sliding doors difficult to open and close without using the button?
The door tracks are greased at the factory . By now, the grease in the tracks of your 2005 Montana has disappeared or become contaminated. Also, the rollers have become contaminated with dirt. Cleaning and regreasing of both tracks and rollers should result in a marked improvement.
Nov 19, 2015 | 2005 Pontiac Montana SV6
Reset maintenance light
Try this...
Turn the key to the 'on' position.
Press the trip button meter until it displays the "Trip A" odometer.
Turn they key to the off position.
Then while holding the trip meter down, turn the key to the 'on' position. 4 blinking dashes will display and they will count down.
When the last dash disappears 000000 is displayed to indicate the maintenance counter has been reset.
May 14, 2014 | 2005 Toyota RAV4
I am using this to play my newborns nursery CDs and was wondering if there is a repeat function. I don't want his cd to stop after the last song, and can't seem to find that function. I do not know if I am...
Repeat play (Remote control only)
Press [FM MODE/REPEAT] on the remote
control before or during play.
The player will play all the tracks or all the
programmed tracks repeatedly. " " appears
on the display.
To cancel repeat play, press [FM MODE/
REPEAT] again. " " disappears.
Hope this helps you!
Mar 14, 2011 | Sanyo AWM-660 CD Shelf System
Digital display has disappeared on dash.Was ok
Some VFR's had a problem with the printed circuit board behind the clocks. A track or two could corrode away giving all kinds of electrical faults. If you can remove the dash unit you may be able to see any lost tracks and repair them by soldering in a bit of wire.
Jan 23, 2010 | 1998 Honda VFR 800
Deteriorating sound quality sony mps NWA3000
Reload the songs, or buy an audio editing program
Jan 24, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Walkman lost tracks
um try to check ur memory card.. coz every mp3 u save goes to the mem card.. ^_^
Jul 14, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Ilo mp3 player and memory/files
You need to run chkdsk on the player. Plug it into your computer using the usb cord. Go to Start, Run, and type in chkdsk f: (or whatever drive your ilo shows up as). You'll get an option to repair the corrupted files. This worked for my ilo which had the same problem.
Mar 06, 2007 | iLO (2 GB) MP3 Player
Standard Horizon Chart Plotter CP180 GPS Receiver Logo
16 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
rey francis basa
rey francis basa
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
