Question about Maytag MBB2256G Bottom Freezer Refrigerator
About week later the freezer has snow everyehere ans is feozen solid
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
How do I defrost my frozen freezer?
the defrost circuitry is not defrosting the unit due to a defectice defrost heater,thermostat or adc control,shut it off and let it defrost manually or use a hand held hair dryer to assist in the manual defrost,then remove the inside back wall cover in the freezer in there you will find the defrost heater and thermostat,have towels handy as when you manually defrost it you will have a lot of drainage and the catch pan in the back that catches this water will most likely overflow
Jan 31, 2013 | Maytag MBB2256G Bottom Freezer...
I have an Amana refrigerator with the freezer on the bottom (Model# AFB2534DEW. About a week or so ago things in the freezer were extra frozen (ice cream was rock solid). Then a few days later our...
you need the defrost heater replaced by the sounds of it.
when u unplugged it you allowed the build up of ice on the evaporator to melt therefore increasing the air flow again.
Regards
Ian
Apr 17, 2011 | Amana AFB2534DE Bottom Freezer French Door...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
The fridge stops cooling because the freezer coils freeze up
If you are saying the coils in the back of the freezer section are becoming solid with a light snow and ice, and not allowing air flow, you have a defrost problem. If you unplug and let it all melt with the door open it will run ok for about three or four weeks depending on humidity and use.(you also have to manually defrost it to find the problem to fix.
To repair you need to replace one of three parts the bimetal thermostat, the defrost control, or the defrost heating element. Can not tell you without testing circuit with a meter. It the bimetal has a pushed up top it has got water in in and failed, otherwise you need a meter..... good luck
Jan 22, 2010 | Amana Refrigerators
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Solid ice behind freezer panel door
your refrigerator has something wrong in the def system. the most common problem is the def thermostat.
Dec 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Maytag MBB2256G Bottom Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
