Question about Onkyo TX-SV727 Receiver
Turn off protect mode tx - Onkyo TX-SV727 Receiver
4 Suggested Answers
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
SOURCE: Protect Mode
How do I take that off
Posted on Apr 14, 2012
May 07, 2010 | Onkyo TX-SR605 Receiver
Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Mar 19, 2009 | Audio Players & Recorders
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Protection mode
you have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Mar 31, 2008 | Onkyo TX-SR502 Receiver
Protect Mode
Is it doing this while you have it turned right up? Most systems have protect mode because you are trying to draw to much power or amps through them. Are you trying to run to many or to large of a speaker through them all systems have rate output if you try to exceed this they go into protect mode so you don't blow the amp.
Dec 10, 2007 | Onkyo TX-DS676 Receiver
Aug 28, 2007 | Onkyo TX-8511 Receiver
Help
You need to replace the internal fuse.
Aug 25, 2007 | Onkyo TX-SV454 Receiver
Stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Aug 16, 2007 | Onkyo TX-SV454 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
46 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
