Question about MGE Pulsar M 2200 (68411) UPS System
Min invert volt 707 - MGE Pulsar M 2200 (68411) UPS System
12v battery won't charge replaced inverter and battery got 13.6v coming out of the inverter and only 12 at the battery
inverter problem as it is a required voltage of 14.5 volts to charge a 12 battery ( a fully charged battery is actually 13.2 volts as 6 cells of 2.2 volts each = 13.2 volts )
Jul 24, 2017 | Inverter Electronics - Others
Tip
What size of inverter do I need?
The correct size of inverter is an easy calculation and important to ensure long life from the inverter and the life of the appliances getting there power from the inverter. To calculate you take the volts and multiply by the amps which equals the wattage. Every appliance has a tag which must state the volts and amps. Locate the tag to find the information. Here is an example.
Under Counter Refrigerator 1.3 amps (120 volts x 1.3 amps = 156 watts)
Microwave (120 volts x 10 amps = 1200 watts)
Alarm Clock Radio (120 volts x .03 amps = 3.6watts)
TV (120 volts x .6 amps = 72 watts)
You now add all the watts together, since the above list could likely be running at the same time. There is a combine wattage of 1431.6 watts. In this example you would need at least a 1500 watt inverter. However given some unknown variables personally I would get a 2500 watt inverter. Less stress on the inverter, will lengthen the life of the inverter. Had the total been 1,000 watts a 1,500 watt inverter would suffice.
You must also remember that your alternator on your vehicle must be able to keep up with the power demand of not only your vehicle needs but your inverter needs as well.
on Apr 23, 2010 | Electronics - Others
Does not work on heat mode...all other modes work.. on heat mode defrost and run lights are on for a few min then flashes F5 for a min then repeats the process.
If I understand you have 120 volts but no 12 volts. Most likely the main 12 volt fuses or switches are bad/blown/off. I would start looking near the house battery and work out from there. Some battery charger/converters have internal fuses that can blow if the battery is hooked up backwards. The 12 volt fuse box usually has a main as well.
Don't forget to look for inline fuse holders and if this is a trailer, look on the tongue for 30 amp breakers near the battery that look like rectangular silver boxes. Some have resets on the ends and others are like fuses.
Mar 22, 2015 | Senville Aura Series 27,000 BTU Tri Zone...
How to charge it
Does it come with a 12 volt charger with the small round end or a 120 volt receptor..if 12 volt most any 12 volt with that plug will work..the 120 any extension chord..other way are use a plug that has a cigar lighter plug in each end you can plug it while driving it will charge..or you can simply attach it to the battery like jumping it and let your car run for a few min or unti the full charge light comes on when the test Button is pushed....tip after using it to jump let it attached for a few min after the car starts that will replenish the power used to jump..Good luck
Feb 05, 2014 | ITec Portable Power Station wJumpstarter...
Please i need PANASONIC DV 707 manual inverter
I need panasonic inverter manual
Model No :DV-707H1500BC
KW :3.7
Capacity :380-440V
Serii No :00010012
Mar 13, 2011 | Kitchen Ranges
Can A cobra inverter be plugged in to 115AC for DC 12volt output
in a word no!,,,,it cannot and you may blow it up if you hook it up to the 115ac volt supply,,,in side it there is a switch mode power transistor,,that bumps up the 12 volts to 115 volts it only works the one way,,that is 12 volts dc in and 115 volts ac out,,,,
Feb 22, 2010 | Cobra 2500w Power Inverter
Insignia 27" sound and video was going out replaced power Supply and now just the video goes out after 20 min to 1hr
open the set up and check to see if if the 24 volt supply is going out all voltages are labeled on the power board and the 24 volt suply will be on the plud that goes to the inverter board keep in mind the baard you just replace was not a new one they are pull outs from junk or damages units
Dec 09, 2009 | Insignia IS-LCDTV32 32 in. Television
New batteries new cables still 99 volts output from trace inverter
What kind of inverter is it and what kind of meter are you using to check the voltage with? If the inverter puts out modified sine wave, you have to use a true rms volt meter to accurately check the voltage with. A non rms volt meter will show a low reading.
Sep 21, 2009 | Xantrex Technology Trace Series Inverter /...
Lowering my bill
The best you can hope for is 100% efficiency. Sadly, most chargers are only .707 percent efficient when they convert the AC to DC. So charging the battery is going to lose 30% of the electricity your paying for, even if the inverter is 100% efficient, which they aren't, they are actually probably close to 90%, you lose more money converting the DC power back to AC. Not to mention that the average battery loses 1% of its charge over a month. Your better off just following published conservation topics to save on your electric bill.
Nov 18, 2008 | Xantrex Technology Ags Harness Cable...
MGE Pulsar M 2200 (68411) UPS System Logo
476 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
