Question about Pentax MZ-60 QD 35mm SLR Camera
Av flashing on the LCD. hte shutter won't work and none of the buttons work. I've tried swapping the batteries over so that the top one is ont eh bottom and it worked for a bout 5 minutes. I thought the batteries might be flat so I changed them. It went back to flashing Av again. What is wrong with it?
  • pun_o_mattic Jun 20, 2009
    Yes. No 2 solution worked. Thanks! I thought the camera + Lense was a steal at $55 au and now I KNOW it is! Thank you so much
  • 744 Answers
Hi i will give u the possible solutions. try out these solutions and one among these will work for u
1)you need to go into the menu , select settings and change av appurature setting to 2 instead of 1
2)with the lens compatibility / connection, U can fiddle around with the lens and try to find whether the aperture ring on the lens had moved from the 'A' (auto) setting to the one manual settings and when u switch it back to the 'A' setting it will solve the problem!
3) The lens is not completely set on the mount, maybe a little extra push in the turn may lock it in position properly
4)The contacts are dirty on either the camera mount or lens and it's blocking communication between them (but they hae to be very dirty though)
5)Highly unlikely, but you may have forced the lens into the mount the incorrect way (need to match the red dots). If that's the case you may have damaged both camera and lens.
but try out the solution no.2 that i have provided u... it will fix ur problem perfect
Posted on Jun 20, 2009
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
The volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower
You can't reset it you have a sound problem circuit that needs to be fixed by a qualified tach.
Nov 01, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Aug 30, 2011 | Canon PowerShot A630 Digital Camera
My Dell desktop is stuck in sleep mode. I press the power button and it just flashes amber. Tried pressing the power button for a second but it still doesn't come on. I've also tried taking the...
You seem familiar with these technical issues so I'll assume you have swapped keyboards, Can you actually access BIOS, check if everything is online, Reset the Bios settings to their default (There should be an F button at the bottom)and try and reboot and hopefully this will work, there is a chance your motherboard has an issue try finding out the manufacturer and see if they can provide any help.Best of Luck
Jun 07, 2011 | Computers & Internet
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
How do i turn the auto ISO off?
In the Basic Zone modes, you don't. The camera automatically sets the ISO in the range 100-800.
In the Creative Zone modes (P, Tv, Av, M, and A-DEP), press the ISO/Flash Exposure Compensation button (rightmost button in front of the top LCD panel). This will display the current setting on the top panel. While looking at the top panel or in the viewfinder, turn the command main dial (just behind the shutter release button) to change it.
Apr 14, 2010 | Canon EOS 40D Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Pentax MZ-60 QD 35mm SLR Camera Logo
67 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
