Question about Frigidaire Dryers
Humming noise Constant loud humming sound. It's still drying cand drum is turning
  • Frigidaire Master
  • 5,323 Answers
SOUNDS LIKE MOTOR GOING BAD OR SOMETHING IN THE HUB BEARING ASSEMBLY GOING BAD
Posted on Dec 20, 2014
  • 60 Answers
SOURCE: Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Posted on Sep 18, 2007
TheMobilian
  • 8220 Answers
SOURCE: dryer makes a loud noise when drum turns
loose blower wheel
Posted on Dec 15, 2008
reddyanantha
  • 205 Answers
SOURCE: my dryer is making a loud humming noise. what
this is because of bearing worn out so lubricate the bearing or change the bearing then check the noice.
Posted on Oct 08, 2009
  • 2122 Answers
SOURCE: Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Posted on Mar 20, 2010
heatman101
  • 43501 Answers
SOURCE: I get a loud humming noise . The dryer works good
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 25, 2010
Testimonial: "good answer because i checked the pads and bushing in the back of the drum"
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
Constant loud humming from front of hyundai gets
If the noise get louder as you speed up, it is possibly a wheel bearing, needs checking out by a mechanic.
Jan 27, 2014 | Hyundai Cars & Trucks
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Noise when button pushed to begin dryer.
is it a humming sound and the motor doesn't turn on or is it running and noisy?if it's just humming it's probably a bad motor,try to move the drum by hand,if it turns freely you have a bad motor,if it's running and noisy you could have a bad blower wheel behind the duct that the lint filter slides into or a bad pulley that the belt raps around,bad rollers,there's a few things it could be,you're gonna have to get in there and take a look or call someone in,if it's very old you might not want to put any money into it,next time send model number and a little more info,good luck
Mar 25, 2010 | Kenmore Dryers
Humming noise from stove
Turn the convection oven switch to the off position.
Feb 15, 2010 | Viking Stove/Oven/Range Timer Knob -...
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Dryers Logo
73 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
