Question about John Deere EZtrak Z225 Zero-Turn Riding Mower
Wont start Replaced battery then found a fuse that had melted, replaced, still no start. Just a click
My ford falcon xr6 au tickford series 3 2003 wont start
Check if you have a main fusible link which is a wire that is suppose to melt to prevent the smaller relays from damage. It would be a wire from the battery to the main fuse box or a wire from the starter relay bundle to the main fuse box.
May 16, 2018 | Ford Cars & Trucks
Why asd fuse keeps blown
You have a Chrysler , dodge , or Plymouth ? ASD Fuse supplies power to ASD relay ,if you have a Dodge , Chrysler or Plymouth vehicle . You have a short to ground , videos on you tube , how to find a electrical short ! ASD - auto shut down , this powers Ignition system , fuel injectors , O2 sensors . A short in any one of these systems will blow the fuse . O2 sensor wires get melted on exhaust pipes an manifolds ! That is if you have one of these make vehicles !
Sep 28, 2016 | Cars & Trucks
2006 Dodge Grand Caravan - One morning was dead(single click). Battery charged/tested = Good. Starter tested = Amps/Volts within range, sounded a little rough, Bendix sometimes slow to engage. Replaced...
This looks like an electrical problem. A burnt wire and melted fuse at a component are only symptoms of a problem up the circuit. It may be possible that the fuse in the fuse box is rated higher than required and caused the failure at the component.
The circuit may not be getting the correct current to get your engine started immediately. It will entail a lot of work and running a same-rated new wire can be helpful in reducing the occurence of missed starts but may not eliminate it altogether.
Hope this helps.
Nov 05, 2013 | Dodge Cars & Trucks
1990 Buick Century Limited 6cly wont start turn over or crank
Usually if the battery is dead, you will hear clicking. If the battery is good then I would check any Starter fuses/relays. If they are good then I would check for power to the starter solenoid. You can find many youtube videos on how to check this.
Scott
ASE Certified Automotive Technician
ASE Certified MED/HVY Truck Technician
Jan 23, 2013 | Buick Century Cars & Trucks
Fuses melting in 98 beetle
Firstly you've gotten a damaged harness , maybe there are some heated wires which are fused together .
Dec 28, 2017 | 1998 Volkswagen Beetle
Fuse blows when starting car
Probably a short from the battery to stater. Maybe have come in contact with exhaust and melted. Is it a Chevy
Feb 01, 2018 | 1993 Toyota Tercel
My 1997 Ford f150 won't start. It makes a clicking sound On the passenger side by the battery.
I have the same problem with my '97 f150....same clicking noise and wont start. I replaced the sylanoid..(however you spell that)......then I replaced the battery...then I replaced the starter...I checked all the fuses...still doing the same thing...
May 20, 2010 | Cars & Trucks
I have a 1998 k2500 5.7 liter.I turned the key and noticed no instrument cluster lights,the fuel pump wont turn on.I found a 40 amp maxi fuse blown under the hood.I replaced it and the lights came on as...
Recheck the wires coming from the starter, for rub-thru, and grounding. Commonly a wire gets pinched between the starter and the starter housing. Wiring touching or near the exhaust manifold can melt, check there too :)
Sep 12, 2009 | 1998 Chevrolet K2500
Wont start
you may be having a problem with the connections on the battery or your selenoid on you starter is goin bad
Feb 16, 2009 | 1996 Chevrolet K1500
John Deere EZtrak Z225 Zero-Turn Riding Mower Logo
14 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
