Question about Bosch Classixx WVF 240S Front Load Washer / Dryer
Wont completely drain or spin but pump sometimes
Pump will at times pump out part of the water but wont complete pumping and will not go to spin cycle
SOURCE: Washer fills wont spin out or drain water
I had the same problem. After releasing the door and removing the wet clothes, I siphoned the water from the drum. Make sure that the water is turned off and the machine is unplugged, Then I opened the large black cap behind the round white cover on the surface. Be prepared to capture about half galon of water. This is the opening to the drain pump. In my case, there were some toys from my kids which had stuck in the turning part of the pump. I removed them and replaced the cap to the pump. Everything seemed to be OK after that.
I hope that this helps. Please be adivsed that I am not a repair person and proceed with caution and use common sense when dealing with electric appliances.
Good Luck
Posted on Nov 08, 2008
SOURCE: Washing machine is not completing cycle
Had the same thing. Managed to sort it out by checking a few things and getting my hands dirty.
First things first: Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier - I couldn't so I ended up reaching in from the back.
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there (I had about five quids worth of change stuck in there which was where my issue was located).
If you've found no obstruction by now I'm afraid that I'm stumped :-(
Best of luck.
Posted on Aug 19, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
barkencoa
  • 3463 Answers
SOURCE: The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Posted on Jan 28, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer wont spin
The safety latch could be worn or stuck, the lid not closing tight enough to disenage the safety lever
Apr 20, 2013 | Washing Machines
Washing machine won't spin in the spin cycle. The model # is GWL11US the serial # is EYN654081 I tried to get the date of purchase and couldn't ascertain that info. CAN YOU HELP!
check that ALL of the water has been pumped out you could have a partally blocked drain pump causing the water level pressure switch not to be satisfied that the tub is completly drained. If tub is NOT completly drained it wont spin but it will usually give you an error code try drain spin to see if that works draining it a second time
Feb 12, 2010 | Fisher and Paykel Washing Machines
Does not complete spin cycle
Ok, when this happens, its usually because of a drainage issue. the spin cycle has to work in conjunction with the drain pump to remove the water during the spin cycle and, if there is a clog or drainage issue, the spin cycle will shutdown. check the following to address this drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Frigidaire Washing Machines
G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Mar 28, 2009 | GE WJSR2080V
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Oct 27, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Sears 110.23812100 washer leaks when spinning
There is a pause after the pump out that shift the tranmission into spin also if you open the lid the unit will go into spin before it pumps out completely . They have since fixed this issue...The newer models work offf the pressure switch to tell the unit when to go into spin only after the water level switch is open telling the machine there is no water left in the unit
May 28, 2008 | Washing Machines
Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
15 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
