Question about Whirlpool Dryers
Thermal fuse keeps blowing
What causes the Thermal Fuse to blow?
the dr
  • 447 Answers
SOURCE: Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Posted on Nov 19, 2007
larryyb
  • 291 Answers
SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Posted on Mar 09, 2009
  • 132 Answers
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Posted on Mar 27, 2009
aasc
  • 1606 Answers
SOURCE: Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Posted on Sep 05, 2009
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Thermal fuse blown on kenmore dryer what is the cause
The thermal fuse blows when the vent gets restricted and builds up too much heat. After it gets to a certain point the thermal fuse blows. Clean out the vent, keep the lint trap clean, and hopefully your problems will go away.
Feb 04, 2012 | Dryers
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
Russel Hobbs RHNPC800P Slow cooker keeps blowing the thermal fuse. What would cause this???
two things, the thermostat allows the cooker to get too hot or the thermal fuse rated temperature is too low. Try get a thermal fuse with about a 10 deg higher rating.
Apr 18, 2011 | Russell Hobbs RHNPC800P 8-Quart Slow...
Keep blowing fuses
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Dryers Logo
14 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
