Question about Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer
How to fix washer leaking from bottom when spenning
Leaking form bottom when spenning
    Sergeant:
  • 272 Answers
Might be the hose from tub to pump or pump to outside. Check each by raising the unit and do a spin cycle.
Posted on Feb 17, 2015
STILL Leaks after parts replaced...and now water level sensor issue.
there is a small pipe that runs from the drum buttom to the diafragma sensor water level
(it's a round thing 5" at the highst point in the machin) this item close a sircet and close the water inlet.
please chace for cracks or blocks in this pipe
all rhe best
Dec 17, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
The washer don't work don't wahs n don't spen
You need to replace the lid switch on the washer lid.
Jan 03, 2011 | Maytag LSE7806A Top Load Stacked...
What dose it mean when your washer leaks from the bottom
make sure it is leaking from the bottom!
sometimes there is a problem with the dispenser leaking which in turn runs down the trim of the machine, around the door housing and looks like it's from under the machine - look for evidence of this in the form of run lines from the bottom centre of the door. If this is the case you will need to either clean the dispenser housing or replace it depending on the level of soiling.
If it is an actual leak from the bottom of the machine the you'll have either a perished pipe or work connections
Jun 12, 2010 | Whirlpool WFW8300SW
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
My Maytag LAT2300AAE is leaking but not from the water hook ups and the drain hose appears to be in good shape. Where else would it leak?
check the seals at the bottom of the washer many times they will form cracks or connections will loosen
Mar 08, 2010 | Washing Machines
Old GE washer, agitater starts, tubs stats to move
The main seal on the tranny is leaking. This is a cheap and easy fix. This machine is worth the effort to repair it by the way. Here is what you do and it is fairly easy to do although it sounds complicated. Remove the agitator and the tub anti wobble. Then remove the inner tub. Get the tub eal off and then remove the tranny. Flip it over and remove the bottom. Knock out the seal and put a new one using a little oil to lubricate it. Add 2 quarts of motor oil to the tranny and put it back together. Re install the tranny and she will be good as new. Nothing is complicated about this repair and no special tools are needed.
Dec 20, 2009 | Heating & Cooling
Leaking washer
Water pump impeller seal has worn out. Easy fix part is around 50 bucks
Apr 12, 2009 | Washing Machines
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Fisher Pakel 4 years old Water leak
possible its form the pmp assy underneath, youll need to tip unit back( the bottoms open, look for leaks, should be quite noticable
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer Logo
48 people viewed this question
Top Sears Washing Machines Experts
pawnpower
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
