Question about Sanyo 18KS52 Air Conditioner
How to change setting
Cannot change th temperature setting.
My viera plasma th-42px80 TV set is in Japanese language, i don't have a remote control. how can i change the language to English language?
http://www.ebay.com/itm/HQRP-Remote-Control-for-Panasonic-TH-42PX80U-TH-42PZ700U-TH-50PX500U-TH-50PX50U-/352010105393?hash=item51f56ff231:g:g-wAAOSwCU1Yz9xg
Apr 21, 2017 | Televison & Video
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
Frigidaire electric oven mod cfeb786jgs3 cannot see th tempurature indicator
Good Morning Friend,
I understand that you are unable to see the temperature display on your Frigidaire range, model# CFEB786JGS3. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before setting the temperature for your oven. If you are still having trouble with the display, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire Ovens
Adjust brightness on panasonic th-50px60
The TV's Brightness setting only affects the intensity of the color white. The easiest way to see changes is to pause a movie or TV show that has clouds in the image. Then change your Brightness setting to your preferred video.
Mar 18, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
How a cooling fan should work
The cooling fan is thermostatically controlled and enerised once the radiator/engine temperature exceeds that of the thermostat controlling th the fan. If the fan is coming on prior to the engine reching the operational temperature, then either the thermostat is not functioning or ha been wired incorrectly into the system the radiator was changed.`
Jun 09, 2012 | 2001 Toyota Camry
Air not working blows hot air no matter what you set it on,temp switch does change temp at all ,compressor seems to be kicken on
there should be switch w/a cable & should be next t/th 2 small hoses coming out of th 'fire-wall' see if its moving, when u switch th "temp" switch from th inside on th DASH..
Apr 09, 2011 | Toyota 4Runner Cars & Trucks
Panasonic TH-L32S1OZ digital TV set. Message on
Make sure the cable is hooked up then press ok on your remote (or enter). If you have your tv hooked up a different way (like hdmi) just change the tv source to the correct one.
Mar 04, 2011 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sanyo 18KS52 Air Conditioner Logo
20 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
