Question about Panasonic Vacuums
My new Panasonic bag less vacuum has no suction whatsoever from nozzle on hose when it's released from its housing
Agent Don
  • 310 Answers
SOURCE: no power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
renevacdoc
  • 84 Answers
SOURCE: My hoover has no suction at the nozzle
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Posted on Nov 05, 2009
SOURCE: Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Posted on Apr 17, 2010
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
The vacuum is blowing air out, no suction into the machine
It may have a clog or obstruction somewhere but if it is blowing air out it has to be pulling air in from somewhere. Check all areas from the brush roll area and nozzle housing up through the tubes and hoses and into the bag compartment. If you have not changed the belt in over a year it may not be able to pick up anything even if it has suction.
Feb 25, 2011 | Simplicity Vacuums
All fo a sudden, no suction, motor runs fine, no clogged tubing.
Be sure the upper attachment hose is inserted firmly into the lower hose into the nozzle. Check for suction at the end of the hose, and if there is no suction there must be an obstruction in the hose, or the filter inside the bag compartment is plugged. Be sure the brush is turning when the handle is released.
Jan 18, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum keeps spitting dirt back out. will not **** up the dirt
Check the hose for clogs. This problem is generally caused by the power nozzle brush running, but there's no suction to pick up what it sweeps to the hose, so debris just keeps getting scattered.
Disconnect both ends of hose. Drop a marble or similar small item down one end of hose and lift hose until the item comes out other end. If it doesn't, there's a clog. You can try to clear it by connecting the hose to the exhaust port, sticking other end in a plastic garbage bag, and turning on vacuum. That should clear it.
If the marble does roll out, another possibility is a leaky hose, one with cracks, holes, and similar things that would cause a leak.
There are other things that could cause a loss of suction, but these are the most common.
A bad switch is also possible, but less likely.
Oct 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
Disassemble electrolux olympia one vacuum.
Four nuts in rear housing, deep inside. Motor slides out after they are removed.
Jan 17, 2010 | Electrolux Vacuums
Attachment nozzle no longer has any suction.
Your hose is clogged or there is a internal clog. If the motor is running, there has to be suction unless the hose is clogged. Check everything between the nozzle and the bag ... everything.
Thanks
a
Oct 20, 2009 | Vacuums
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Vacuums Logo
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
