Question about Behringer XENYX 2442FX Mixer
Cannot get good signal from aux sends to my powered monitors. this mixer is brand new qx2442 behringer
4 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: how do i hook up a powered moniter to the
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Posted on Nov 30, 2010
mrwtech727
  • 75 Answers
SOURCE: how to connect a Behringer XENYX 2442FX Mixer to a
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Posted on Sep 01, 2011
  • 5603 Answers
SOURCE: i want a labelled diagram of behringer 2442fx mixer
Here: http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Posted on Dec 09, 2011
How to connect Echo/delay/repeat to mixer that enable me to setup/control all 12 channels on my mixer
You have built in effects that you can use - if you're trying to connect off board effects as well you need to use one of the aux send/returns.
Oct 23, 2013 | Behringer XENYX 2442FX Mixer
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
How to connect a Behringer XENYX 2442FX Mixer to a laptop
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
Does it work with ordinary speaker or must be preamped
You will need a power amp for the monitors or powered monitors. I also use Behringer, they are good quality for a very good price
Hope that helped
Aug 04, 2011 | Behringer XENYX 2442FX Mixer
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
How do you control volume for a specific instrement in a sub group being used as a moniter mix with out afecting the main mix
Send the signal to the subgroup via and Aux channel PREFADER. This will allow you discrete volume control over your monitor mix.
Jan 06, 2011 | Behringer XENYX 2442FX Mixer
I have a behringer 16 channel board . the 2nd aux send in not working as of last week. What's the general problem that happens when an aux send stops working?.................
I don't believe this board has an "Aux send IN" jack. There are "Aux Send" and Aux Return.
The Aux returns are TRS jacks.
Make sure ALL interconnected equipment are powered from the SAME receptacle or source to avoid damage to equipment.
You might clarify the exact name of the in or out that is not working. I have schematics to help troubleshoot the problem.
Dec 18, 2010 | Behringer XENYX 2442FX Mixer
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442FX Mixer Logo
79 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
