Question about Refrigerators
Sandstrom when fridge doors opened all cuts out
Door not creating suction when door closes
the door may need adjusting
cut an place a strip of paper between the seal and the fridge and close the door
if the paper pulls out easily then the seal is not touching fridge
The suction is created when the warm air from the room that gets into the fridge when the door is opened is cooled down and occupies less space hence the lower pressure and the vacuum forms
May 12, 2016 | Refrigerators
I have a Sandstrom DAB micro Hi Fi system SHFJMC11 and can not open the door (says door key locked)
just inside the ipod cover you will see a thin black plastic flap that is also the ipod lever, protruding into the door. you need to insert a small thin knife and push this flap back so it clicks flush into it's position. this takes the lock off and you will be able to open the door.
Dec 26, 2013 | Cars & Trucks
Sandstrom manual shfjmc11
if you look at the rear of the ipod cover you will see a black plastic flap that is also the ipod lever when it is open, protruding into the door. you need to insert a thin knife blade and push this flap back so it clicks into position flush with its housing. this will take the lock off.
May 03, 2013 | Radio Communications
Why is my samsung fridge is power cut off when the door open
fridge indoor bulb wiring short,check the wiring line
Mar 29, 2012 | Samsung Refrigerators
Beko fridge freezer left door open all night in error
If the door was left open the fridge compressor would have run without a cut off and so would have resulted in an error. Please shut down the fridge fully remove power for about 6 hours and restart.
Nov 26, 2011 | Refrigerators
My refrigerator stopped working because I left the door open for like three hours and the electricity does not go to all the fridge parts like the lighting system is off and the freezer is off every thing...
There is no sensor like you stated. Actually, when you keep open the fridge door, the cooling all will go out and hence thermostat sensor would not cut off, as required temp not reached inside the fridge.
So, the compressor would have run for long time without cut off. Due to this the overload protector trips the compressor. Remove power for 4 to 6 hrs. And then restart the fridge. But make sure you close the fridge door. Thanks.
Mar 20, 2011 | Danby Compact Refrigerator DCR-101W
MY FRIDGE CUTS OUT WHEN THE POWER FAILS EVEN IF THE POWER JUST FLICKS ON AND OFF WE CANNOT RESET IT HAS WE ARE ONLY AT THE COTTAGE WEEKENDS, SO WE LOSE EVERYTHING INSIDE
other than running your fridge on its own power source or fitting a gas operated fridge,(bottled gas) you must leave it empty,with the door open.....our friends in Canada have gas for heating and fridge /freezer and a generator, so they dont suffer any power cuts in winter.
Sep 09, 2010 | Samsung RB215LASH
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
