Question about IBM ThinkPad 600E 2645 Notebook
Hdd-1 de 017 error 80 fru 6010 how to fix? - IBM ThinkPad 600E 2645 Notebook
2 Suggested Answers
  • 18 Answers
SOURCE: IBM ThinkPad 600 Hdd error
make sure the Hdd is well connected , and hope its not an HDD failure. Might also want to check see if you didn't disconnect any other wires by changing the battery.
Posted on Feb 28, 2009
I cannot release de left margin on my Xerox Memorywriter 6010. I press de Mar Rel Key and don't have success. Please, Help
Have you tried oiling it w/3-n-1 oil? Often the sticking problem is nothing more than it needs lubrication.
Feb 11, 2015 | Xerox 6010 Memorywriter Electric...
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
Toshia IDE #0 ERROR comes on the screen about 2 mins after starting then as follows is on the screen. .Intel (R) Boot Agent FE ver 1.10.PXE-E61 Media test failure check cable. PXE-MOF:Exiting Intel Boot...
This error is telling you that either one of three things have happened. 1. Your hdd cable has come loose or failed. 2. Your HDD has failed, or 3. the IDE controller on the motherboard has failed. You can check problems by trying a known good hdd in place of your old hdd. If bios sees it then it is the drive itself that is bad not the cable or controller. If it does not see the good hdd then try replacing the cable. If this fixes the problem then remove good drive & replace with your old hdd. Problem should be solved. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
Feb 28, 2009 | IBM ThinkPad 600E 2645 Notebook
PROBLEM WITH ERRORS HARD DRIVE DEV-017 ERR 81- FRU 6010 APRECIATE
As you boot up the computer, keep on pressing the F8 key, you will be able to get into the Windows Startup Menu and be able to select Safe menu.
You most likely have a problem with a bad block in the page swap file area.
You may still not get Windows to open, and basically your need to format the hard disk and this will lock out the bad blocks and then you can install Windows again.
This also indicated your hard disk is wearing out and more than likely you will get more bad blocks and this will cause further problems such as computer locking up to data file corruption and or loss files etc.
You have an old laptop (it must have come out of the ark), it is not fixing, unless you can get another hard drive very cheaply, put your money towards a new one.
Jan 02, 2009 | IBM ThinkPad 600E 2645 Notebook
HDD both IDE or SATA 1 are not recognized
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Oct 06, 2008 | Abit KV-80 Motherboard
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
