Question about Heli-Max 1SQ V-Cam Quadcopter RTF HMXE0836
Won't lift off - Heli-Max 1SQ V-Cam Quadcopter RTF HMXE0836
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Lifting deck won't lift
Inspect the linkage connecting the lever to the deck. That's what I would do.
May 14, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lift is out of vehicle and won't go up or down
Sounds like the jack screw has bound. That requires a complete disassembly and inspection to see if it just needs lubrication or a part.
Feb 27, 2013 | Pride Backpacker Avp Lift SSBPAVP
My r key won't lift up, how do you fix that?
usually the typebar link is off or broken. Lift the key up manualy and see if its attached. If it is broken only an expert can fix it. If it is off you may be able to reattach it if you are mechanically inclined.
Hope this helps
Dec 11, 2012 | Smith Corona Office Equipment & Supplies
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
I have a 4310. The three point lifts only under high rpm and won't lift any weight at all. Cleaned screen and replaced suction and trans filters. Still have problem.
A 4310s 3-pt should be able to lift approx. 1-ton at 24inches on the 3-pt lifting arm. I thought there was a hydraulic reservoir and a transmission reservoir and it is not uncommon to put the wrong fluid in one of those You might check that transmission fluid didn't get in the hydraulic tank.
May 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
Where do I find the front hood release on the car?
Bottom left next to driver's door is the pull handle.
Reach under the hood (you may have to pry a bit to get your fingers in there, particularly if the hydraulic gas lifts are dead so the hood stays down), slightly down and right from center. There's a flat lever you'll push right to release the catch.
Have about a 4' stick handy to prop it up if the lifts are dead, and make sure it's someplace which won't slip, if you do that.
Lube the mechanism with light oil such as 3-in-1 while you're there, and replace the lifts if they won't hold the hood up, not a big deal to do or costly...
Apr 16, 2011 | 2000 Mercury Grand Marquis
Heli-Max 1SQ V-Cam Quadcopter RTF HMXE0836 Logo
35 people viewed this question
Top Heli-Max Toys Experts
ray gallant
Are you a Heli-Max Toy Expert? Answer questions, earn points and help others
