Question about Garden
Coil wire is too short for the Stihl 46 trimmer. Wire fails.
Wire insullation fails after being stretched over time and shorts against the engine, resulting in a no start.
3 Suggested Answers
  • 1212 Answers
SOURCE: trooble shooting for possible fuse or relay or blown breaker from internal short from wire shorting out
That coiled part is a current or voltage sensor depending how they connected it. The shorted wire "may" have just blown a fuse on the control board if it was supply voltage for the sensor. The control circuit voltage is a nominal 24 volts, often tapped off from a winding on the cooling fan. So trace where those wires go and you should find the fuse or fuses for the control board. If the control board has a "pico fuse" it may be difficult to locate. b ut replacing it and the wire in theory should correct the problem.
Posted on Sep 26, 2012
plink_plonk
  • 1807 Answers
SOURCE: bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Posted on Mar 16, 2013
Broken wire on stihl 029 saw.
one of the wires will go to a stop switch as that will be the method of shorting out the coil to stop the engine
Jun 03, 2017 | Stihl Garden
I have a stihl chainsaw MS 08s and I keep getting electric shocks, does anyone know why
The 08s has a metal shrouding.
1) The spark plug wire could be shorting around it's exit hole.
2) A coil 'kill' wire could be rubbing or shorting to the housing
3) The kill switch can be shorting internally
Jan 10, 2017 | Stihl Garden
Is there a correct way to connect the two wires to coul pack on a fs38 stihl line trimmer, it came back to me in peices from the mower shop after a ridiculous qoute to replace coil
one wire ( normally a short wire with an "O" end terminal) will go under a coil mounting screw
the other will go to the stop switch /button
probably will have a bullet type connection
The high tension lead will go to the spark plug
Sep 25, 2015 | Stihl Garden
No spark after renew of coil and plug.
Assuming you have read other posts here about air gap and have it set approximately correct, the next thing to do is disconnect the cutout wire from the coil (small wire with spade connector). When you hit the kill switch, this wire is grounded to the chassis of the saw, which prevents the ignition coil from generating a spark. Often, the insulation on this wire can fail, allowing the wires to short against a metal part, or the kill switch may be faulty.
If you have spark with this wire disconnected, check the wire itself for any breaks. If it looks good, then the only thing left to check is the switch.
****Don't try to start and run the saw with the wire disconnected, because if it starts, you'll have no way to stop it****
Aug 24, 2015 | Garden
Stihl pole saw no spark
Sounds like your coil has gone bad, usually when a coil fails the symptoms are as follows: intermittent spark when engine is hot, then no spark until engine cools down, and eventually no spark at all.
Jul 12, 2013 | Garden
Blown inj fuse
It could be a short in the wiring-a bare wire touching metal, but sometimes an injector will go bad and short out blowing the fuse. Try unplugging all the injectors, then put new fuse in and turn key on. If fuse blows again, it must be a bad wire in the injector circuit. Each injector has a power wire and a ground wire, the power wire probably derives from the engine computer, and the ground wire definitely goes to the computer.
If the fuse didn't blow right away, try connecting one injector at a time (key on). If connecting one injector causes the fuse to blow-that is a shorted injector. It will have to be replaced.
If connecting all injectors did not blow the fuse, try the wiggle test on the wires, with key on. You may cause the fuse to blow by wiggling or moving a section of wire, and that is the likely source of the short. Separate the wires and examine them closely. Look for exposed wire, melted insulation, things like that. Look for where the wiring harnesses may chaff or rub against something, may be stretched or stressed. If you still can't find it, you may need to run continuity or resistance tests on each individual injector wire. For that you would need a multimeter, a good digital volt ohm meter (DVOM) at a reasonable price is a necessity for automotive work.
Apr 25, 2013 | 1997 Saturn SL
How to check if the spark plug fire
Hi there ,
Please remove your plug wire from plug. If you have removable cap of wire tip, just remove it. Then use the plier ( with good insulation) to hold your wire. Use non electrical conducting shoes. Then make a gap ( about 1 mm) between wire tips and metal body ( or engine ) of your bike. Short start your bike and see how the the wire tips spark the electricity to your bike. If it has nothing your coil or coil incoming power is fail. If your have blue spark, you have tip top condition of coil.
Best regards, vote please, Jay
Feb 26, 2011 | 1988 Honda VFR 400 R NC24
My trimmer cranks good and starts off running good. After about 5 and sometimes as long 10 mins it will suddenly start running 1/2 speed. I 'm guessing something is getting hot and causing it to miss fire?...
the ignition coil is shorting out...it's a stihl thing...seen it too many times...get another coil...if it's new, it's under warranty (a dealership "must" repair to get warranty)...
May 31, 2010 | Garden
Stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Sep 17, 2009 | Garden
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
