Have a daewoo top loader air power washing machine with a problem light le showing what could be wrong
5 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
kapishtech
  • 2272 Answers
SOURCE: Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 11, 2010
SOURCE: I have a DAEWOO DWF-1150P top loader washing
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Posted on Jul 10, 2011
Why I keep getting a flashing lE light flashing on my daewoo front end loader washing machine
ie is a problem with water inlet'check no hoses are kinked behind machine and that water is fully on
Nov 20, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
Mode W/M-DWF-200MP
Apr 29, 2010 | Daewoo Washing Machines
Waher showing LE and not wahing
if your machine is an LG , then le code means your motor senor or motor is faulty.if u r confident change sensor first.is it a top loader or front loader?the sensor is attached to motor. if u would like more help please reply. if u r getting service company 2 do job, ring around 4 prices on changing sensor or motor. this should save u money
Apr 06, 2010 | LG Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
