Question about IBM Infoprint 6500 Matrix Printer
Infoprint 6500 error codes - IBM Infoprint 6500 Matrix Printer
Good day how do I fix a problem on the IBM 6500 printer not powering up. The power supply has been to be OK. The main board has been replaced. The fans are not running etc.
If you replace the main PCB you need to move the Key over or it won't post (grey squares on the panel with no fans on). It is a small 3-pin plug near the flash memory slot.
In addition to that if you have the V5 controller you would need to move the Flash memory chip and the DRAM.
After you do that you will need to load the microcode on the PCB. I can get you instructions to do this.
V5 MRP provides IT Parts Product Supplies and Services
V6 MRP provides IT Parts Product Supplies and Services
Sep 14, 2015 | IBM Infoprint 6500 Matrix Printer
Default username and password for IBM Infoprint 6500
Username is root and there is no password if you are going in through the GUI. If for some reason that doesn't work try root as the username and blank as the password.
Nov 30, 2010 | IBM Infoprint 6500 Matrix Printer
Change setting
You hace to save settings in the config menu, sometimes they dont save so its better to change settings by using web brouser and pc.
Feb 18, 2009 | IBM Infoprint 6500 Matrix Printer
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
To add paper size in IBM infoprint 6500
Start,
Settings,
Printers or ..,
Files,
Server Preporties
and a create new form
matrix or inc
Dec 19, 2007 | IBM Infoprint 6500 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
168 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
