Question about Scotts Company Scotts Ortho Weed-B-Gone Lawn Weed Killer RTS 32oz
What is the ratio of water to ortho weed b gone
I have an Ortho Whirlybird seed spreader. What setting to use for spreading 3 lb/1000 ft of Prozon Weed Beater?
I too have been going crazy trying to find instructions for this seed spreader. Go to Ortho Products online and select chat. Tell the agent the UPC code for it, which is: 71549-08450. They can then email you the one-page instruction sheet for it. Otherwise try this site where I uploaded it: http://pdfcast.org/pdf/whirlybird-spreader
Jun 22, 2012 | Bonide """bonide"" prozone weed beater"
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I am confused. Your driveway weed killer says 1 quart per one gallon of water, and the dial n spray has just ounces on the top up to 8 ounces and up to 32 ounces to be filled on the side of container....
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
Aug 21, 2011 | Ortho Dial N Spray Hose End Sprayer
How long should I wait to determine if my application of Weed B Gone is 'working'?
Weeds treated with Ortho Weed-B-Gon Chickweed, Clover & Oxalis Killer Concentrate will show visible signs that the product is working within 1 to 2 weeks. A repeat application may be necessary in 2 to 3 weeks for hard-to-control weeds. Initial signs that the product is working are wilting and yellowing of tender new growth. Necrosis (tissue death) then spreads to the rest of the plant. The weeds wither, turn brown and die.
Sometimes it appears that weeds are still growing and going to seed even after they have been treated with Weed-B-Gon Chickweed, Clover & Oxalis Killer Concentrate. These seeds will be sterile because the chemical will have reached them within 1-2 days of treatment. If you have any further questions please feel free to contact Ortho @ 1-800-225-2883
Mar 07, 2011 | Ortho Chickweed Clover Killer Pint
Sprayed yard two weeks ago and appears chickweed is spreading. No sign that the Ortho Weed b Gon for chickweed is working . The chickweed is actually blooming with tiny white flowers. I live in VA.
I am sorry that the Ortho Weed-B-Gon Chickweed, Clover & Oxalis Killer did not control the common chickweed as expected.
The active ingredient in Ortho Chickweed Clover and Oxalis Killer is Triclopyr, Triclopyr is very efficient at killing tough to control weeds, but it does take a lot longer for it to show results that it is working.
Weeds treated with Ortho Weed-B-Gon Chickweed, Clover & Oxalis Killer will show visible signs that the product is working under optimal conditions ( usually 65-85 degrees F) within 1 to 2 weeks. A repeat application may be necessary in 2 to 3 weeks for hard-to-control weeds. Initial signs that the product is working are wilting and yellowing of tender new growth. Necrosis (tissue death) then spreads to the rest of the plant. The weeds wither, turn brown and die.Sometimes it appears that weeds are still growing and going to seed even after they have been treated with Weed-B-Gon Chickweed, Clover & Oxalis Killer. These seeds will be sterile because the active ingredient will have reached them within 1-2 days of treatment.
If you give it another week and still see no yellowing, twisting or curling, you may want to reapply. If that still doesnt work, or you have any further questions give us a call at 1-800-225-2883 to see what else we can do.
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
I have a winter weed,looks like a clover of some type and as the season matures, it will sprout a yellow flower. It is just starting to grow and would like to kill it before it gets out of control. ...
this weed is called yellow wood sorel and i would be surprised if any ortho product will kill it, need to know what type of turf you have and what region you are in to reccomend a product
Dec 20, 2010 | Ortho Chickweed Clover Killer Pint
For general weeds what ratio round up to water do i use? thanks Jon
The recommended ratio is 50-1 or 2.8 ounces per gallon of water...
This gives a good kill in most cases...
heatman101
Sep 30, 2010 | Roundup "" Weed & Grass Killer
Scotts Company Scotts Ortho Weed-B-Gone Lawn Weed Killer RTS 32oz Logo
59 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
