Question about Garden
Husqvarna lawn mower brake linkage stuck - Garden
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
  • 62 Answers
SOURCE: Key start on lawn mower does not work
Check your starter fuse..follow ignition wire to starter..there is a fusable link inline. make sure u have power all throughh line to starter. :)
Posted on Sep 07, 2009
  • 11 Answers
SOURCE: how to reset oil change indicator on my husqvarna
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Posted on Sep 06, 2010
  • 11 Answers
SOURCE: belt installation diagram for a husqvarna riding
Depending on the year - here is the link for manual that will show the diagram
http://weborder.husqvarna.com/order_static/doc/usa/2009/I09000/I0902011.pdf
If you have any questions, please call John at 860.233.5439 x222 or visit www.ButlerPower.com
  • 3074 Answers
SOURCE: need a belt diagram for
ttp://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CHUS%5Cimages%5C90%5C35%5C0019.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=23
Posted on May 22, 2011
The forward / reverse pedal of my Husqvarna TS 138 mower is jaming. Was working fine until today when it stuck in forward. After engaging the brake it did release but then got stuck in reverse.
Sounds like it may be rubbing something, or there is a lot of debris in the linkage. Start by inspecting the linkage and pedal to make sure it isn't hitting/rubbing anything as you move it with your hand. Clean and lube connections and any visible bushings. If it's still a problem, it may be internal. Perhaps there is a buildup of stuff internally causing it to stick.
Apr 14, 2017 | Husqvarna Garden
How to replace the brakes of husqvarna lawn mower?
unfortunately, you are one of the lucky owners that has one of these things. You are going to have to remove the transaxle and break it down in order to replace the brake pad, "IF" you can find a replacement part! My suggestion is to double check the linkage and use you owners manual to see how you can or if you can adjust the linkage. Replacing the pad is not all that difficult but it is very time consuming. If you have to remove the transaxle to replace the pad, please be sure you have a breakdown list so you can disassemble and reassemble the transaxle correctly. You will need to find the exact model number on the transaxle and then look it up online and download a copy and print the breakdown section. Good luck.
Aug 14, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The brake pedal on my husqvarna riding mower gets stuck, what do I do?
It might need adjustment -going down to far--spray linkage with WD40.
Aug 14, 2014 | Garden
Husqvarna problems
Follow the cable to make sure it isn't stuck. If the cable moves freely, check that the flywheel brake and any attached springs are connected properly. These are usually under the pull start cover.
Jul 19, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Husqvarna New Zero Turn Lawn Mower RZ4623 will not go into gear
Not sure the problem, there are no gears on the drive system. This uses Hydro drive wheel units. If the belt is on and in good shape, check the lever linkage.
Jun 22, 2014 | Husqvarna New Zero Turn Lawn Mower RZ4623
2007 Sienna rear wheel stuck dont think it's the hand brake
Not sure why this is in a Husqvarna post... but anyway, regarding the 2007 Toyota Sienna I assume you're talking about:
You probably have a stuck brake caliper. They're easy to change, just search YouTube for a video, and look at this link:
http://www.ehow.com/how_5805469_tell-need-new-brake-calipers.html
Dec 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Wheels will not turn on my Husqvarna CTH150 Twin lawn mower
you either have a drive belt that is off, or, you have stuck brake shoes on the back.
Oct 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Huskee LT 4200 modle 13aj771g031 how do I get the small rear drive belt to go on the pully
Set the brake/clutch. This will disengage the linkage that tensions the main drive belt, allowing you to put it on the pulley.
I hope this is helpful.
Aug 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna won't go forward or backwards.
The brake is stuck on. Happened once before and I was able to force I back up. This time is won't come back up.
Sep 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Jun 06, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
