Question about Electric Demolition Jackhammer
I need an attachment to a electric jack hammer that you can drive 2x4 stakes into the ground with to set up forms for concrete to be poured. the sleve needs to fit a 2x4. Does anybody make anything like this?
    Brigadier General:
  • 8,619 Answers
Hi
You can buy the attachments from the following links:
Demolition Jack Hammer Attachments 1
Demolition Jack Hammer Attachments 2
Demolition Jack Hammer Attachments 3
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
I needed the information to know about concrete drive way replacement. what should I know when the contractor comes to give estimate?
First off you need to make certain that he is going to jackhammer the old driveway and remove it from your property. I guess before that, be sure to get a reputable contractor to do it. Check with BBB if you would like to.. Then jackhammer and remove. Be certain that they are replacing the driveway with the proper thickness. I believe it is 4". They will lay down 4"x 4" wire sitting on little blocks called "adobe" blocks to suspend the wire off of the bottom.Be certain that they put crack reliefs in when they are finishing concrete. Those are the indentations that they put in due to the expansion and contraction of the concrete so it will crack in the indentations instead of on the slab. Be certain that they form up the driveway before the wire. They put 18 or 24" stakes in the ground and then nail the wood formers to the stakes. This is what hold the concrete in. They will pour it in one day then trowel it, install the expansion reliefs and then they will take a soft hair 24" pushbroom and give it a light brush finish. All of the edges will be troweled and rolled over nicely. Be certain that he doesn't over order on concrete. Basically it is length x width x depth 27 cu ft. = 1 cu. yard. There will be a small portion over to allow for any problems. This is normal. The next day they will come back, pull the forms and your good to go. Be sure to get 3 estimates. Good Luck!
Apr 21, 2017 | Heating & Cooling
Tip
Military Antennas
In the Army you are out in a field with a radio, a copper wire, a metal stake, and you pitch a tent. Its a radio similar to Cb radio 2 ways. You can run a wire 34 feet across between two trees about 15 feet up. make sure you tie the wire at both ends with Nylon rope(plastic) to the trees. Take the 4 to 6 feet metal rod drive into earth(ground). Attach center coax piece to wire strung between trees at one end. Attach shield to Ground Rod. Another way is to nail a board about 15 feet up, attach a copper wire 34 feet going out one way and another 34 feet the other side. It will form a Pyramid. Tie to two stakes in ground at both ends with nylon rope. It will make do for a fast Cb radio emergency camp radio. It may get stations 15 to 30 miles away. Try camping on a Mountain top with a portable 12 volt battery,Mobile CB, Copper wire, Metal stakes,plastic rope, Square plastic piece 14 inches long or a board piece.
on Apr 01, 2011 | Radio Communications
I have a 3600w arksen jackhammer. It does not have an oil site gauge on it that I can see. what do I do about adding oil to this unit?
all these types of jack hammers hammers use 40 w oil
its electric
cant find a user manual for it online
if no visible site glass or oil filler
whats the chances you have to undo part of the jack hammer
at the Allen key bolts
reviews say these arksen units leak oil often
Jul 20, 2016 | Cars & Trucks
How to anchor this to the ground?
The best i have found is pour a small concrete form and add threaded studs to it after the pour before it drys hard. If you dont it will go over in a bad storm.
Mar 19, 2016 | Red Shed Windmill, 10 ft
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
How to repair cracks in concrete floors of house and how to make them waterproof
simply chip the conrete cracked maybe up to 3cm wide and 2-3 cm deep the whole way and clean thoroughlly with water and the best is to blow air after you wash with water to take away the loose debris then apply concrete epoxy arround the cracks with clean paint brush # 1-2 let it stay for about 30mins and you feel the epoxy is starting to set before then pour the conrete mix with fine sand that will do the trick.
Nov 05, 2013 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
What tools do i need to repair the rear brakes ? is their also a special tool to pull the rear drum off ?
I don't mean to offend, but if you don't know which tools are required or how to remove the rear drum, the only advice I can give, is to have the brakes serviced by a trained technician. There are certain areas of auto repair that the do-it-yourselfer should not work on. The brake system is one of those. There is too much at stake if the job isn't done right. The safety of you and your family, and the guy in front of you on the highway when traffic comes to a halt at 70mph and your brakes fail. Everybody, me included, would like to think they can fix anything. But there are things best left to the pros. Again, I don't mean to offend, or imply that you are not a good mechanic. It's just the only answer I can give considering the circumstances.
Jan 02, 2011 | Toyota Tercel Cars & Trucks
I want to attach a carport to the back of my garage.The ground around it is of clay with a lot o water in it,the ground freezes and the posts heave.Is there a solution. The ground is low there and cannot...
You will need to pour a substantual footing under your posts
I would suggest using Sonet Tubes of at least 12 inches and 24" deep, setting on at least 8" of 3/4 minus gravel, then fill tubes with a good 5 or 6 bag mix of concrete, once it sets surround the concrete with gravel well tamped, You can install connector plates for your posts in the top of the concrete.
You need to have enough weigh and surface so that the water and soil cannot heave the footing
Mar 30, 2010 | Tanaka TIA-350s Post Hole Digger -...
Pouring concrete
I live in N.W. Wisconsin and they do pour cement in 20-30 degree weather. They have the concrete supplier mix with hot water and also add calcium chloride. The ground must be thawed with no frost in it. They pour the cement and if finish it and then cover it with tarp blankets. This does add cost to the project and if you can wait for warmer weather I highly recommend you do.
Hope this helps.
Bob
Feb 22, 2009 | Plumbing
Electric Demolition Jackhammer Logo
538 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
PHiBrOpTK
Level 1 Expert
Are you an Electric Hammering Expert? Answer questions, earn points and help others
