Question about Milwaukee Tool Hammering
Kango 340 keeps tripping out mains - Milwaukee Tool Hammering
I have a kango 900k breaker, the con rod has broken, is it possible to obtain a replacement part. Thanks
Its the ask if its a MILWAUKEE kango 900K yes but if its a KANGO 900K the metal red or metal blue demolitionhammers its difficult to find but the cause of the broken con rod when the machine is not good air tight it can have has burned o-rings and more also the battle cilinder can be torned and piston pin not smooth enough and ,more parts of the original English KANGO are not simply deliverable anymore, but for the American milwaukee red 900k its not a problem
http://services.milwaukeetool.nl/jsp/material.jsp#part0239
Jan 24, 2014 | Hammering
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
Need Parts List And Service Guide For Kango 990/950 Breaker
If these are the original Kango kangos then you are out of luck. They have been obsolete for many years now and no parts have been manufactured for a long time. The name was bought by DeWalt and they didn't do much with it. The Kango name is now ownd and used by Milwaukee, but there machines do differ alot from the originals. There were a few main models and the main mid sized breakers were the 900 (hammer only) and 950 (rotary hammer) There were a few facelift/variations of each (K, X and B I think) and they did use a couple of different sized seals/pistons/cylinders.
If it is one of the Milwaukee models you can look up diagrams here...
http://www.milwaukeetool.com/
Apr 24, 2012 | Hammering
I cant find kango oil for my kango electric hammer
What kango hammer do you have? I am most familiar with the UK kango 900 and 950, pre-milwaukee.
Sep 18, 2010 | Hammering
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
What type of oil should I use in a Kango electric hammer type m(di) ? Is it possible to get a parts/service manual for this (I realise it is old. Thanking you in naticipation of a reply-Charlie
\charlie use sewing machine oil, as for a book on it put the make model into google and a pdf might be available as for parts not really unless you sroce them through the paper or ebay
Apr 24, 2010 | Hammering
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Aug 11, 2009 | Hammering
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Hammering Logo
69 people viewed this question
Top Milwaukee Tool Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Tool Hammering Expert? Answer questions, earn points and help others
