Question about Ott Light Home
I replaced the bulb on my ott light. It still does not work. What else should I try?
My light is a floor lamp
  • 9 Answers
SOURCE: C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Posted on Apr 16, 2008
jmgldsmth
  • 1889 Answers
SOURCE: MD5880N replaced bulb and worked for 2 hours now nothing
Place heat shielding around the lamp to prevent overheat; use cooling spray (freon) to cool any chips or, circuit boards near the lamp as you attempt to start the set check the lamp for the correct serial # voltage etc.
Posted on Aug 02, 2009
  • 610 Answers
SOURCE: lamp light is blinking as well as the red standby
If the bulb did not fix it then it is probably the ballast that has gone out or the power supply board has failed. I usually replaced the ballast and power supply together. You can call 1-800-samsung or search online for the parts.
Posted on Jul 13, 2011
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
I had projection bulb go out (explode) in my toshiba DLP tv. Pulled out bulb and housing assm. and could see it. Ordered a replacement bulb online, an aftermarket one and replaced it. Lamp led would keep flashing, blue led on, sound ok but still no picture. You could hear tv going through its self reset and after eight attempts red lcd came on. Info online suggested lamp door not seated properly, rechecked and door fine. I pulled bulb housing and made sure it was completely seated and it was in as far as it goes. Checked bulb housing contacts and they looked ok. The aftermarket housing assm. did not "feel" the same as the original when installing into tv even though they looked identical. Swapped new bulb into old housing, cut old harness and plug off of bad bulb and crimped on new ends at bulb end reusing original plug and harness (observe new bulb harness to keep wire locations correct) reassemble and install housing. Worked as soon as tv turned on. Watch out for non oem parts, they may look identical but something may still not be quite right.
Posted on May 17, 2012
  • 17 Answers
SOURCE: maytag Serial Number 2256KEQ3 - Freezer light will not work - Bulb has been replaced
change switch contact bad
Posted on Jul 15, 2012
2009 buick lacrosse console gear indicator bulb
Transmission Floor Shift Control Indicator Lamp Replacement
Remove the front floor console. Refer to Front Floor Console Replacement.
Rotate the floor shift control indicator lamp socket (2). Pull the socket from the trim bezel.
Remove the bulb from the socket.
Preliminary Procedures
Remove the rear floor console. Refer to Rear Floor Console Replacement.
Remove the instrument panel lower trim plate. Refer to Instrument Panel Lower Trim Plate Replacement.
Set the parking brake, then shift the transmission into drive and push the shift indicator down until it locks, to allow clearance to remove the console.
Front Floor Console Screw (Qty: 2)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N·m (18 lb in)
Front Floor Console Bolt (Qty: 2)
Tighten
10 N·m (88 lb in)
Front Floor Console Assembly
Front Floor Console Retainer Clip (Qty: 2)
Feb 24, 2017 | 2009 Buick LaCrosse
I have tall reading lamp not ordinary bulbs
Is there a question in there somewhere? And maybe some info on the "Tall reading lamp"
Nov 24, 2014 | SPOT Light Bulb Lamp (SPOT)
Why does my Ott light flicker but not come on completely?
check and replace bulb first, if not that then most likely a ballast problem, which sends a boost of the correct amount of power to ignite the bulb then lessens the flow of power it needs to stay lit.
Sep 06, 2014 | Ott Light OttLite Truecolor Table Lamp
Is it the ballast or the bulb which is faulty?
Put a new bulb in, if it works, the bulb was a problem, if it still flickers, the ballast is a problem.
Apr 10, 2014 | Ott Light OttLite Truecolor Table Lamp
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
The on/off switch seems to be broken
If you haven't used it in a while or if it is in a cold area, it may be a warmup issue, try turning it on a waiting a few seconds, even in the best time there is a delay. You are correct to expect the bulb to last a long time most Ott bulbs do last!
Dec 06, 2012 | Ott Light OttLite Truecolor Table Lamp
Removal of burnt out bulb in ott lite
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
Sep 12, 2010 | Ott Light OttLite Truecolor Table Lamp
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
Home Logo
122 people viewed this question
Top Ott Light Home Experts
Donni Steen
Tom Chichester
Are you an Ott Light Home Expert? Answer questions, earn points and help others
