Question about Konica Minolta bizhub Office Equipment & Supplies
C2831 Troble code - c2831
  • Konica Minolta Master
  • 6,161 Answers
At model machine
Posted on Dec 30, 2015
How do I fix a troble code po641
with gm cars, the code indicates a bad 5 volt reference signal that is sourced inside the engine computer. it feeds lots of sensors and circuits, so any one of them could be shortimg out the wire. the wire could be broken somewhere, or the computer might have a bad refulator in it. without lots of time and testing, this error probably wont go away.if you lack the skill and time to chase wiring and voltage, i would take the car to the dealer.a local mechanic might take a long time and a lot of unneeded parts to fix this problem.
Sep 23, 2014 | Vehicle Parts & Accessories
I HAVE ML500 MERCEDES BENZ 2006. THE CAR CRANK WELL BUT DOES NOT START, I CHANGE FUEL PUMP, FUEL FILTER, CRANK SENSOR, SPARK PLUG AND MASS AIR FLOW. BUT THE CAR IS SAME PROBLEM.. WHAT IS THE POSSIBL
does this car have a timing belt on it did it break , open the air box spray a little ether in it should start ,do not disconnect anything just do this , get back ,
Sep 15, 2014 | 2007 Mercedes-Benz ML500
2006 Volvo xc90 trouble code po101
did you reset code,any vacuum leak.
Mar 08, 2013 | Cars & Trucks
1999 wrangler troble code p1687
there is a code table here: code table, hope it can help you
Oct 31, 2012 | 2004 Jeep Wrangler
What is troble code u0002
are you sure the code begins with u as all my technical data codes for hyundai all begin with p. let me know and i will try sort it for you. thanks
Feb 17, 2012 | 2002 Hyundai Accent
Tata indigo dicor trouble code p1200
what is thep1200 troble code in tata indigo cs dicor
Feb 10, 2012 | Tata Indigo Cars & Trucks
My Troble code is ND What is it
The ND error code is NO DRAIN it means the water according to th ecomputer didnt drain with in the normal time and a blocked pump or fitler screen on the pump is blocked.
GENE
Aug 06, 2011 | Amana Washing Machines
Getting a trouble code of 1b with no definition. also have 12.15 volts at maf
12.5 with the engine running? Should be battery voltage and you need the find the loss. The Maf should have ground as good as the battery ( common to fail by 2 volts ( needs fixed)) Power should be battery ( common to be 1/2 volt off) Singnal wire should be 5 volts unplugged with the key on and not running. Troble code not common as thats not the normal way their numbered what makes you think you have troble is the check engine light on ? Who checked these codes and what makes you think theirs a maf problem? What does the car run like ? Stall hesite, bog not start drink gas fail to pas? Sentras go like hell and stop on a dime if theirright and they stay that way till they blow or lose an injector ( injectoe failure is common over 150 thou.) Mileage ( unknown) Manuel or auto ( unknown) driving problem if any ( unknown)
Nov 02, 2009 | 1998 Nissan Sentra
NTL 54 01 EUROVOX CODES FEB18-2009
5C 01
OB F2 52 72 4E 1B 86 90
83 61 00 3A FD F3 DC OA
Feb 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
