Question about SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive
I have a rock mobile disk I turn it on and it has a blinking red
I have a rock mobile disk it was working fine but I moved my computer and when I connected the hard drive it has a red blinking light and it's no longer found in my computer what happened? how do I fix this problem?
  • chibcha10
    chibcha10 Feb 21, 2012
    Hi there, I like to know if you fix the problem, I got the same situation??
    my e-mail its chibcha10@hotmail.com
    Thanks!!
  • rustytigger1
    rustytigger1 Jan 03, 2013
    Same here rustytigger28@yahoo.com
  • 21 Answers
Open the case; you'll probably find it contains an old worn-out drive. "Rock Mobile Disk" is just the brand on the case; your seller is notorious for packing used and refurbished drives into cheap, unventilated cases and selling them as "new". They overheat and die very quickly. You might contact the vendor (eBay seller, right?) if they still exist, but the best you can hope for is an equally bad replacement.
Posted on Oct 20, 2009
Hey guys, im not too technically savvy but thru the yrs ive realized that common sense and simply covering all holes b4 proceeding to complicated and maybe expensive measures, is a very effective way of solving computer problems sometimes. I own a rock mobile disk as well (magnetic whatever hdd inside), its done this b4, but usually after unplugging and replugging the power itd work, this time it didnt ...at all..so I CHANGED THE CASING, and now im backing my files onto another hdd. that solved everything, the hdd IS plug and play for most computers, i think the casing's psu is kinda flimsy, and gives out quick.
Posted on Jan 27, 2010
  • 85 Answers
Try reloading the drivers, might have to run a search for the product and delete all softwere first, but just try to reload drives and go from there. If nether of these work it may be a registry error wich I can help with but lets try this first.
Posted on Jun 20, 2009
I didnt have to download a driver but all i get is a red light on mine i dont know how to make it go away
Posted on Jul 24, 2009
My Hitachi Touro 500gb suddenly did not work? no light indicator and not recognized by the computer..
Hi,try to use other usb cable,and insert it also to other usb port of your computer.But if its still not working..go to my computer right click..see the manage,..see the disk management..there you found your hard disk but if doesnt appear on it..it means that your har disk was dead or defective already..thanks
Aug 20, 2011 | Hitachi 500GB Touro Mobile USB 20 HDD Hard...
I have external toshiba harddisk MK1234GAX .when i connect to my laptop its not detecting only red and green light blinking..its not showing on my computer..i need all the files in tht hard disk..please...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 21, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
I have a transcend 500 GB hardrive, and it was working perfectly fine, but now when i connect it to my mac, a message pops up saying "The Disk you inserted is not readable by the computer." I...
First, connect the hard drive to the computer. Go to the search bar in the top right and search: Disk Utility. Then select your hard drive (not a subsection, the actual hard drive). go to the First Aid tab, and click "repair disk".
If this does not fix it, then I am afraid that your drive is dead.You may have abused the product in some way (dropped it, dropped it while it was on, bumped it, didn't drag the drive to the trash can, etc).
Feb 25, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device now displays a red light, next to the standard green light. I tried...
The disk-drive inside the enclosure has "failed".
Open the enclosure, remove the disk-drive, and take it to any computer-store, to buy a compatible replacement. Install the replacement disk-drive.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My Rock Mobile Disk Drive is not working. Every time I connect it to my computer, the red light flashes and after a while of clicking, I get an error message screen that says "The specified I/O...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 12, 2010 | SimpleTech SimpleDrive...
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Rock Mobile Hard Drive (External) Red Light
How long did you wait. I bet it's fragmented all to heck and just takes a while to read all the data.
Apr 18, 2009 | SimpleTech SimpleDrive...
Clicking and blinking red/yellow light
Hello
Click HERE.
Kind regards
Andrea
Jan 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive Logo
2,530 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
