Question about LG Washing Machines
How to remove the hose on washing machine LG wd 16220 fd
Error oe
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Posted on May 18, 2009
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the little basket out that's behind the small door on the lower left front (where the drain hose is) and look inside. The drain pump intake is about an inch in on the left. Make sure there's nothing in there like a paperclip or hair pin. If possible reach in and see if you can turn the impeller. If it won't move there's something in there if it will turn then the motor is probably bad.
worked for me
got this from mark1963
Posted on Jun 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: OE Error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 15, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
OE Error
Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
