Question about Cognitive Printers Cognitive LBD422043013 Thermal Label Printer
Cognitive label printer ERROR 0212 - Cognitive Printers Cognitive LBD422043013 Thermal Label Printer
A small part of the label is faded out and the scanner can't read it. How do i fix it? Product: Cognitive Advantage LX label printer.
First, try cleaning the printhead with some isopropyl alcohol on a clean rag. If this doesn't work, send in for service.
Jan 07, 2010 | ATSI Holdings Cognitive Advantage LX BD24...
Our Blaster Advantage prints too low on label
Printer needs to be calibrated. This can be accomplished through the driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 12, 2009 | ATSI Holdings Cognitive Blaster Advantage...
There is a label stuck under the roller. This is causing the labels to jam when printing.
Platen roller needs to be taken out to remove label. Recommend, sending unit in for service.
Nov 15, 2009 | ATSI Holdings Cognitive Blaster Advantage...
PRINTER PRINTS ONE LABEL THEN DISPENSES 4 TO 5 MORE BLANK LABELS. UNABLE TO RESET WITHOUT TURNING UNIT OFF AND REWINDING LABEL ROLL. WE HAVE A COGNITIVE LX THERMAL PRINTER.
Printer needs calibrating. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Oct 10, 2009 | Label Accessories Cognitive Thermal Label...
Blaster advantage printer does not print in proper spaces on labels
Try calibrating the printer. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Jul 29, 2009 | ATSI Holdings Cognitive Blaster Advantage...
We are facing the same problem
Jun 11, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Align advantage blaster printer
Download the Printer Setup Utility at cognitive.com.
Apr 14, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Cognitive Blaster Advantage PROBLEM
Printer needs to be calibrated. This can be accomplished through the printer driver or setup utility.
Apr 10, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Printing off to one side after reloading drivers
Make sure the roll of labels are pushed all the way over to the left in the label bucket.
Mar 23, 2009 | ATSI Holdings COGNITIVE Thermal Label...
Cognitive Del Sol LX continually spitting out labels
Try calibrating the printer. This can be accomplished through printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 13, 2008 | ATSI Holdings COGNITIVE (LDD42-2083-013)...
Cognitive Printers Cognitive LBD422043013 Thermal Label Printer Logo
56 people viewed this question
Top Cognitive Printers Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Cognitive Printers Office Equipment and Supply Expert? Answer questions, earn points and help others
