We recently moved and the the 2 'feet' my digital piano stand on were broken. More accurately the plastic coverings were snapped, the metal base below is okay. I'm trying to find replacements and haven't been able to track down where to order these parts. It's for the Yamaha Clavinova digital piano.
Experiencing discomfort or pain in your ears while playing your Technics digital piano is not a normal occurrence and could be a sign of an issue that needs attention. There are a few potential reasons for this phenomenon:
Frequency Range: It's possible that certain frequencies produced by the piano are resonating with the natural frequencies of your ears or the surrounding environment, causing discomfort. This could explain why you feel it more in specific ranges of the keyboard.
Acoustic Properties: The sound produced by the piano might be reflecting off nearby surfaces or causing standing waves in the room, which can create resonances that affect your ears.
Volume Level: If the piano's volume is too high, it could lead to discomfort or pain in your ears. Even if the volume seems moderate, it's possible that specific frequencies or overtones are causing issues.
Headphones: The fact that you don't experience this issue when using headphones suggests that the problem might be related to the piano's built-in speakers or its interaction with the acoustics of your environment.
Electronic Components: There could be a malfunction or interference in the piano's electronic components that is affecting the sound output in a way that causes discomfort.
To address this issue:
Volume Control: Try lowering the volume of the piano and see if the discomfort lessens. Gradually increase the volume until you find a level that doesn't cause discomfort.
Room Acoustics: Experiment with placing the piano in different locations within the room to see if it affects the sensation you're experiencing. You could also try using soft materials like curtains, rugs, or acoustic panels to dampen reflections and standing waves.
Equalization: If your piano has an equalizer or tone control settings, try adjusting them to see if it reduces the discomfort.
Professional Inspection: If the issue persists, consider having the piano inspected by a technician to check for any electronic or acoustic anomalies.
Expert Advice: If none of these steps resolve the issue, it might be best to consult with an audiologist or a professional musician who has experience with piano-related sound sensitivities. They might be able to provide more personalized advice and recommendations.
Your health and well-being are important, so it's essential to address any discomfort or pain you're experiencing while playing your digital piano.
Paul, inside of the Clavinpva at the rear where the power cable connects to the board. there is a 124 volt 1.25 amp fuse. the old type that is a glass cylinder with silver ends. it's an easy fix and will cost about $3.00 for a pack of four. You have to9 take out all of the screws on the bottom of the piano in order for the top to slide off, but you can do it in about 15 minutes!
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Thanks- just what I was looking for!
