Question about Thermador C301U Electric Single Oven
Emilie model EL965EL how to replace oven door hinges
Does anyone know where to buy hinges and how to replace the hinges
2 Suggested Answers
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
Mar 06, 2013 | Ovens
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
Need fitting instructions to replace door hinges as manual misplaced. thank you.
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Oct 10, 2010 | Neff B1421 Electric Single Oven
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
Apr 12, 2010 | Stoves 720EF Electric Double Oven
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
Neff b1421
Replacing the door hinges is the only solution to this problem.
Sep 29, 2008 | Neff B1421 Electric Single Oven
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Thermador C301U Electric Single Oven Logo
15 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
