Oven not working error message se:-0
SOURCE: I have a Hotpoint range model RGB745BEH. The oven
Check the glowbar ignitor in the oven. If it does not glow or glows weakly replace it. If you are handy with a amp meter you can check the ignitor. If it shows 3 amps or less,replace the ignitor.
SOURCE: I am getting error message FC on oven control
FC Communication error between boards Wiring harness or power relay board (PRB)
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According
to the Frigidaire technical documentation, most likely the cause of the
problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
