Paper tray is full but fax machine isn't pulling the paper through the machine
boyrevel
  • 71 Answers
SOURCE: FSending and receiving faxes on legal size paper.
Press Menu/Set, 1, 3 Press up or down arrow to select Letter, A4, A5, A6, B5, B6 or Executive Press Menu/Set Press Stop/Exit :o)
Posted on Aug 14, 2007
SOURCE: fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Posted on Dec 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Sharp F0-5700 Fax No Paper (Tray)
Remove the tray out of the copier and look for one next to the feed tires.
Posted on Jan 08, 2009
iservice
  • 318 Answers
SOURCE: Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Posted on Jul 03, 2009
SOURCE: I have a Canon Laser
I will advice you Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button. Press the "Resume" button four times.
Press the "Power" button. The error code is now reset, and your device should work fine.
Take care.
Posted on Sep 14, 2010
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
Paper jam
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
May 21, 2009 | Canon Office Equipment & Supplies
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Jan 08, 2009 | Sharp FO 5700 Plain Paper Laser Fax
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
Jul 01, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Check paper tray - reload paper
Your paper sensor actuator arm is most likely broken or out of position, or you may have a dirty sensor if you are in a dusty environment. If you look in the machine with the tray out, you should see a small (usually black) piece of plastic hanging down. You can also take the toner and drum cartridge out and turn it on its back to get a better look. If it's not there, it's probably broken off.
Feb 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
MESSAGE O A PANAFAX UF-790 STATES CHECK CASSETTE MESSAGE IN MEMORY
Check cassette means the paper feed tray. Pull out the paper tray, put in fresh paper. Close the paper tray and see if it starts to print. If not, let me know Ed
May 30, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
15 people viewed this question
k24674
jasbo
jasbo
