Question about Kenmore Refrigerators
Water in the bottom of inside refrigerator
Drain line clogged
docjohn174
  • 943 Answers
SOURCE: CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: water leaking in refrigerator on shelves, drawers, and under draw
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Feb 09, 2009
We took the back bottom vent cover off. Clean that area of lint. We than followed the advise given to another posting of a refrigerator link. This has seemed to work for now, time will tell. However we were told most people with Haier refrigerators have problems. Thank you.
Posted on Feb 16, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
Fridge drain hole blocks with ice every few days, fridge icing up inside too. I've tried defrosting thoroughly manually.
Check your drain line for clogged .Clean it out .
To verify that it's clean pour water in drain line and you shold see water coming down into a drain pan at the bottom
Jun 01, 2017 | Refrigerators
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Water on the inside floor of refrigerator
The freezer line will be the one that dumps water into a tray next to compressor where it evaporates.You need to take off the back panel of the freezer compartment to access the freezer drain. It will be a hole located below the coils and may be clogged with food matter and/or ice. A vacuum cleaner works great for this. Hope this helps
Jul 29, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Mar 24, 2009 | Refrigerators
My whirlpool refrigerator is leaking water inside the refrigerator. i have no water or icemaker on mine. its just a regular old fridge about 9 years old. i keep it clean and vaccum out the bottom every...
Water can leak from these areas:
Here's what to do:
Jan 06, 2009 | Refrigerators
Leak
It leaks Water can leak from these areas:
Here's what to do:
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    Refrigerators Logo
    63 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
